insulation for c3
Old Jan 12, 2008 | 09:14 PM
oh6driver's Avatar
oh6driver
Default insulation for c3
well i have seen some other threads on insulation for the interior. so my question is do go buy the insulation kits from ecklers, corvette america or lowe's is it the same stuff. and will it do the job the same as insulation for the car. I am replacing all the carpet in the car will it work under the new carpet or will i have more trouble then its worth. also i have bought dye paint for the interior trim and have heard that it fade's out in just a couple of weeks any thoughts on dye or replacement $$$ scott.
Old Jan 12, 2008 | 10:40 PM
autimous's Avatar
autimous
I want to do exaclty the same thing in mine. I've got a new interior kit from Wilcox and I was wondering about insulation and dye kits.
I want to go from faded blue to black.
Anyone??????
Old Jan 12, 2008 | 11:10 PM
74Blackfoot's Avatar
74Blackfoot
I put down a single layer of refletix (the stuff from Lowes) and a double layer against the bottom of the firewall. I forgot about the transmission hump the first time and I could literally feel the difference between the insulated and uninsulated areas. I went back and put a layer down over the transmission hump and I don't have any complaints about it.
Dynamat makes some sound deadener and heat insulation combo mat if you want to shell out the $$$$.
Old Jan 12, 2008 | 11:21 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I used reflextix on my 77 as well. worked great for about 20.00 from lowes. But I used 2 layers on mine. I put new carpet in from al knoch int.
Good luck.. Lets see some pics.
Old Jan 13, 2008 | 12:00 AM
chvet73's Avatar
chvet73
Default Insulation
I've used the expensive and the Lowes type, both are a big improvement. Couldn't tell the difference from one to the other.
Old Jan 13, 2008 | 12:11 AM
74Blackfoot
Half-way through, Passenger side
Passenger side
Transmission hump, near emergency brake. From the looks of this picture I did put down two layers.
I had some left over… well a lot actually, since I bought the bigger of the two rolls.
T-Tops, I'll put a headliner over them someday. Yes, it actually made an improvement too, considering I don't have any shade to park in.
To insulation for c3
