There have been several posts on verifying an LT-1 that I have found very informative. I'm wondering if someone can post similar information on things to look for on a 454. Not sure how much varied from year to year, but the car I'm looking at is a '70 454.
Well, you have 4 engines available in a 1970 model. If this car is missing its original engine. Items to look for would be half shaft U joint caps instead of u bolts, but again that only eliminates the ZQ3 and L46 engines. LT-1 and LS5 had this feature. If it only has one metal fuel line along frame, this would indicate LT-1 as the other 3 engines use a return line. If it has 2 metal lines but they are closer to the fuel pump location on block, this would indicate an LS5, and would eliminate the ZQ3 and L46 engines as their location is different in respect to the fuel pump. I believe the radiator support is dimensionally bigger on the LS5 than the ZQ3, L46 & LT-1 engines.
Hope this helps.
Paul,
I don't have much to offer, but if you do not have the NCRS technical manual and judging guide it is definitely worth getting. It helped me immensely while searching.
I was distracted by a local 454 car also. It was a 71 coupe that needed paint. Otherwise un-abused, 4 sp with air. I am guessing I could have gotten it for around 18, maybe less.
How many of these things are you going to end up with? Or are you in transition?
Hope this helps.
You say above that only the LT-1 had a single fuel line, is that correct? I have a 70 LS5, original drivetrain, and it only has one fuel line.
Greg, I have one car right now; a '71 LT-1. I'm looking for a second, at the moment I'm thinking either a 454 or another LT-1. I have 2 boys and looking for a second car....something i can work on over the years with each one of them. At least this is the story i tell my wife.
PM sent. I may be interested in that 454 if this other one i'm looking at doesn't pan out. I'd be interested in learning what you know about the car and why you passed on it.
I stand corrected but, believe the big block cars were equipped with a rear stabilizer bar & small blocks were not. It's worth a quick check around the back.
Paul, I don't know enough to asist you, but that looks like a real nice engine compartment......good advice from the other member, an NCRS judgeing guide will help alot. Good luck, john
I can't remember the details but some if not all 70 454/390hp LS-5s came with a dual snorkel air cleaner and a chrome lid. They might have changed somewhere in the middle of production??? Still have mine.
Also no A.I.R pump, and no exhaust manifold plugs. Looks like I see one on the above picture?
I stand corrected. MY LS5 has two fuel lines, supply and return, as it should. It has been a while since I looked at it. Guess my old memory has crapped out!!
