removing the doors
Old Jan 13, 2008 | 09:39 PM
hicswa's Avatar
hicswa
Default removing the doors
Does the doors need to come off to do a body pull on a 1975 coupe, and if so should a brace be put acroos the opening?
Danny
Old Jan 13, 2008 | 10:11 PM
Scott Marzahl's Avatar
Scott Marzahl
Not really but it does lighten it quit a bit, depending on what you are using to lift it with too. I use an engine lift so with the doors off it is pretty easy. A coupe should be fine without any braces, convertibles definately.
Old Jan 13, 2008 | 10:51 PM
hicswa's Avatar
hicswa
Thanks, I will using the straps and a block and tackle setup
Danny
Old Jan 13, 2008 | 10:53 PM
Scott Marzahl
With that setup, I'd just leave them on.
Old Jan 13, 2008 | 11:11 PM
coinwasher's Avatar
coinwasher
If you leave the hinges on the body you only have to remove four bolts from each door and just slide the doors off of the hinges. That is how i did mine and I highly recommend taking them off. You do not need to brace anything. The birdcage is very strong.
Good luck with it, post some pictures.
Old Jan 14, 2008 | 02:27 PM
hicswa's Avatar
hicswa
Thanks. I have another question, do I have to remove the steering column from inside the car, or do I disconnect it from the engine bay? Any tip would be appreciated. The rest of the job seen easy. what is the hardest thing to do?
Danny
Old Jan 14, 2008 | 02:40 PM
coinwasher's Avatar
coinwasher
Danny
I pulled my steering column before the body removal because I was swapping it out for a tilt tele anyway. You can drop the steering box off now (loosen the box and break it loose at the rag joint).
The hardest thing to do was removing all of the mounting bolts
Old Jan 14, 2008 | 03:37 PM
hicswa's Avatar
hicswa
What is a rag Joint? Is the in the engine bay?
Old Jan 14, 2008 | 03:40 PM
coinwasher's Avatar
coinwasher
Yes, it is the flexible coupling between the steering column and the steering box.It is located about 8 inches behind the steering box.
Old Jan 14, 2008 | 05:21 PM
coinwasher's Avatar
coinwasher
Here is a picture showing the rag joint on the steering box.
To removing the doors
