Dome Light
Old Jan 16, 2008 | 01:46 AM
murraybs's Avatar
murraybs
Default Dome Light
Were dome lights an option for the '73 model year? Mine hasn't got a dome light and I'd like to put one in... Digging around for stuff in the passenger compartment without having a flashlight handy is kind of starting to get old.
Thanks guys.
Old Jan 16, 2008 | 07:46 AM
73 red vette's Avatar
73 red vette
Thanks guys.
There should be a light on the back panel below the window that's where mine is. what passenger compartment??????????????
Old Jan 16, 2008 | 07:59 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
it was moved to the roof in late '76.
Old Jan 16, 2008 | 08:30 AM
RunningMan373's Avatar
RunningMan373
It's in the rear of the passenger compartment, if it doesn't work, and you are replacing the buld, be sure to use a TWO post bulb. a one post bulb will short out the wires and fry your rear wiring harness.
Old Jan 16, 2008 | 09:08 AM
Maymyvetteliveforevr's Avatar
I have mine in the roof and it's a '75.
Old Jan 16, 2008 | 12:16 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
I gotta 75 and its on the back of the T-top storage area
Old Jan 16, 2008 | 12:49 PM
GD70's Avatar
GD70
There's also a courtesy light under each side of the dash at the top of the kick panels. When I bought my vette only the drivers courtesy light worked. I pulled the courtesy lens off and when I started to pull the bulb out to replace it, it lit up. Then I jiggled the pass side light and door jam switch and it came on also. All lights come on now, so first check all the bulbs, their connections and the door jam switches.
Glenn
Old Jan 16, 2008 | 02:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Someone installed a 76L/77 t-bar panel and light, then.
Old Jan 16, 2008 | 03:45 PM
steveorino's Avatar
steveorino
From: south of tulsa north of the great state of Texas
My dome light comes on when you open the door of the 81 vette, but how do i turn it on by itself??
Old Jan 17, 2008 | 05:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Rotate the headlight **** all the way to the left until it "clicks" over a slight stop. Standard GM design for many, many years.
Old Jan 17, 2008 | 01:19 PM
Packy76's Avatar
Packy76
I actually cut a hole and put in a light the same as the one in the rear cargo area then spliced into the wiring, I have a early 76 so instead of paying for a new t-bar part I added the light and Im glad I did, it was well worth it , mind you I had the interior gutted at the time so just to do it when the interior is together might be hell !!
Old Jan 17, 2008 | 02:04 PM
I'm the original owner therefore that would have had to be me and I don't remember doing that.
Old Jan 17, 2008 | 09:20 PM
RMS73's Avatar
RMS73
I got a 76L/77 T-bar panel and light base at Carlisle 2 years ago for about $25 and installed it in my 73. Much better lighting now.
Roger
Old Jan 17, 2008 | 10:14 PM
EyeLuvCorvettes's Avatar
EyeLuvCorvettes
I don't know if you have this outlet or are interested in domelights, but there is an led domelight you can buy at www.oznium.com. I forgot to buy it in my last order.
Old Mar 11, 2008 | 03:19 PM
steveorino's Avatar
steveorino
That is what I thought, but that doesn't turn it on. Any ideas?
To Dome Light
