other options for stopped clock?
Old Jan 19, 2008 | 12:43 AM
cruise83's Avatar
cruise83
Default other options for stopped clock?
my clock has never worked, should I fix it or replace with a another gauge..I saw a oil temp gauge in a 81 where the clock was, are there other options?
Old Jan 19, 2008 | 12:45 AM
rayluka's Avatar
rayluka
They make a quartz replacement kit for the clock. I need to do the same
http://www.ecklers.com/product.asp?p...0&dept_id=1652
Old Jan 19, 2008 | 12:47 AM
dahctor's Avatar
dahctor
Just talk with someone today about the quartz replacement and he said they are great!
Old Jan 19, 2008 | 02:13 AM
pbrstreetgang's Avatar
pbrstreetgang
For 28 years, through white trash and hillbillies, my clock still works!
My tach and temp doesn't tho... I'm still the Emporer of the trailer park!
Old Jan 19, 2008 | 02:46 AM
Durango_Boy's Avatar
Durango_Boy
Take the clock out, clean the contacts, re-install it, and it should work great.
Old Jan 19, 2008 | 09:47 AM
cruise83's Avatar
cruise83
now that's good advise. will do that this weekend. thanks.
Old Jan 19, 2008 | 11:12 AM
Mark in BG's Avatar
Mark in BG
Cruising
If you end up having to replace the clock, check on ebay. The same supplier to Eckler's sells direct for about $50 less and free shipping.
I also ended up replacing the printed circuit board on mine. Everything worked except the clock on the original board. The circuit line to the clock had shorted/fried for some unknown reason.
Old Jan 19, 2008 | 12:11 PM
FKING1's Avatar
FKING1
Test it before reinstalling. I replaced mine with a quartz last summer and it works fine,
Old Jan 19, 2008 | 12:27 PM
rcread's Avatar
rcread
i just wear a watch.
Old Jan 20, 2008 | 07:50 AM
82Vettrin's Avatar
82Vettrin
don't remember when, but somewhere back in time, the '82's clock stopped.. I also don't remember what Forum it was on, but I asked what my options were..
someone replied for me to try setting the time by running the hands "backward", instead of "forward"..
I can't explain why or how,, but that's been several years ago, and the only time it's ever stopped or reads incorrect is when the battery gets low from sitting.
Old Jan 20, 2008 | 08:37 AM
cruise83's Avatar
cruise83
That's crazy enough to work, I will try that. Thanks.
Old Jan 20, 2008 | 08:16 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
When you remove the clock, you may see a hole in the back of the clock. I sprayed on WD or some other lube and bingo it started working. I believe the clock is original for my 78.
Old Jan 20, 2008 | 08:36 PM
dbeall1968's Avatar
dbeall1968
I removed my non-working clock, fooled with it and found the copper winding fried. I bought a quartz replacement movement on e bay, put it together in a few minutes, and it works great.
Old Jan 20, 2008 | 11:09 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have the clocks or the movements at this link.
http://willcoxcorvette.com/advanced_...keywords=CLOCK
If you remove the clock from the car, the most common cause of failure is the point set on the electro magnet.
The point set is similar to that of a car and will burn. Once burnt the points can stick, burn off and/or not make contact well enough to throw the magnet arm. You can try to file the points with a jewelers file to get the clock working. You must file them in a matching manner just as if you were filing the points on an old car. In the old days you made the point’s match and filed both sides at the same time to make sure they were matching and not crooked.
This is a common problem with the Borg movement clocks.
We can rebuild the clock in house, you can purchase a new clock, or you can purchase the movement.
Willcox Inc.
CA-8025 1980-1981 Clock. Electric Reproduction 80-81 $124.20
S-3015 1963-1982 Quartz Clock Conversion Kit. 63-82 $69.00
CA-8025Q 1980-1981 Quartz Movement Clock. 80-81 $133.40
Old Jan 20, 2008 | 11:30 PM
chvet73's Avatar
chvet73
Default Clock
I've had my quartz replacement for about 10 years, it works great.
Old Jan 20, 2008 | 11:58 PM
Carl Granquist's Avatar
Carl Granquist
Default Swap & Save
Pulled my original (and mothballed) and installed the quartz movement. I've had super accurate time ever since. No more concerns, except that it is not original. Many times better timepiece, but not what it came from the factory with. It's okay though.
Fuel indicator is my only gauge in the cluster that's off. Oil press, ammeter & temp pretty close. Gas will show "E" and still have ~5 gallons left.
Nearly 37 years old. Fiber optics work, too, so I'm not complaining.
Old Jan 21, 2008 | 03:31 AM
toolman0114's Avatar
toolman0114
I tried but couldn't get my original clock to work again so I bought a quartz replacement. It works great and unless you take it out it looks original. I just replaced the mechanism and used my original face and hands.
Old Jan 21, 2008 | 12:53 PM
Rope-a-dope's Avatar
Rope-a-dope
Mine is only correct twice a day.
Old Jan 21, 2008 | 06:45 PM
SeattleC5's Avatar
SeattleC5
Absolutely the best long term fix for the clock is a quartz drive. Put one in the '72 last year and it was pretty straight forward as long as you are patient and careful. It leaves the original face and hands on the clock which is great. Good lucks
To other options for stopped clock?
