68 vette???
Old Jan 19, 2008 | 12:51 PM
1/4 Mile's Avatar
1/4 Mile
Default 68 vette???
Just a quick question. A friend of mine has a 68 vette. We are trying to see what motor came in this. We believe it is a 427, but are not real sure. What do we need to look for to know for sure.
thanks
Old Jan 19, 2008 | 12:59 PM
parkerracing's Avatar
parkerracing
Are you trying to identify the motor in it now? Or is there a SB or no motor in it? /:\
Old Jan 19, 2008 | 01:14 PM
1/4 Mile's Avatar
1/4 Mile
It has a S.B in it now. But it is not the original motor.
Old Jan 19, 2008 | 03:30 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
one quick way assuming the gauges are original is to look at the tach redline. If the yellow goes from 5400 to 5600 it is 427 390 or 400hp.If it has a very high 6500 redline then it is 435hp 427.anything else it is a small block car. There are other driveline differences (rear end caps ,fuel line etc.) but the tach is a quick way
Old Jan 20, 2008 | 07:17 PM
1/4 Mile's Avatar
1/4 Mile
He dropped the tank and found the build sheet today. It is a 427 car, not sure if it is 390 hp, or 400 hp. Some discrepancy on whether which one it was.
Old Jan 20, 2008 | 09:28 PM
RHD '68 L89's Avatar
RHD '68 L89
The build sheet may list 390HP L36 with an "upgrade" to 400hp L68.
Look at the fuel lines, the tripower had only one from the tank while the Qjet had a return line as well. Tacho redline will be the same for both motors.
Old Jan 20, 2008 | 10:46 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by RHD '68 L89
The build sheet may list 390HP L36 with an "upgrade" to 400hp L68.Look at the fuel lines, the tripower had only one from the tank while the Qjet had a return line as well. Tacho redline will be the same for both motors.
THATS HOW MINE READS !!!
Old Jan 20, 2008 | 10:58 PM
68 NJConv 454's Avatar
68 NJConv 454
mine was 6500 but no original engine. Damn Bubba to hell.
Wish I found a tank sticker.
Old Jan 21, 2008 | 09:46 AM
1/4 Mile's Avatar
1/4 Mile
what will the actual build sheet have on it, if it did come with a tri power?
Old Jan 22, 2008 | 07:22 AM
427SIXPACK's Avatar
427SIXPACK
It would have the option code L-68 for a 400HP tri - power car or
option code L-71 for a 435HP tri-power car
To 68 vette???
