key stuck
Old Jan 19, 2008 | 03:32 PM
kessler's Avatar
kessler
Default key stuck
just installed my rebuilt steering column in my 71, non tilt. I also installed a new ignition with key. I can turn the key but it will not come out. Whats up???
Old Jan 19, 2008 | 10:56 PM
Jim Shea's Avatar
Jim Shea
On the lower end of the steering column (out under hood and under the brake booster) there is a lever. Move it so that it is all the way UP. The lever is connected to a shift tube that rotates inside the steering column and opens a gate up in the column head only when it is in the UP position. You then will be able to rotate your ignition key from the OFF position to the OFF-LOCK position and your key will come out.
This is a link to a paper on the history and operation of the General Motors Steering Column/Transmission Shift Interlock System.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
Jim
Old Jan 20, 2008 | 09:54 AM
kessler's Avatar
kessler
Jim
Thanks, works like a champ
To key stuck
