Dial Indicators
Old Jan 19, 2008 | 06:34 PM
Maymyvetteliveforevr's Avatar
Default Dial Indicators
What would you say is the best deal going for a good quality dial indicator set up for gauging rotor runout?
What other uses are they for on the car?
If you could give the model as well as the approximate going price so I can determine which one would be best suited for me.
Old Jan 19, 2008 | 06:55 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Go to princess auto and get one with magnetic base 20 bucks or less, I built my 406ci with it
Old Jan 19, 2008 | 06:58 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
yup, me too.
Old Jan 19, 2008 | 07:10 PM
Gordonm's Avatar
Gordonm
They will range anywhere from 20 bucks to 100+ for one. Most likely the 20 dollar one will do you a good job. I have a Starrett and Mititoyo one. Both were well more than 20 bucks. I use them quite often in work and around the car. Get one and take care of it and it should last a good long time.
Old Jan 19, 2008 | 08:08 PM
682XLR8's Avatar
682XLR8
Degreeing a cam & checking endplay on various components are two more that come to mind
I have a Starrett also
Old Jan 19, 2008 | 08:12 PM
GTR1999's Avatar
GTR1999
You get what you pay for with tools. The cheap ones are not going to last long if you use them. I went through about 3 of them. They start to stick and if you're not watching or are experienced with them that will screw you up pretty good both in your work and your head.
I use Starrett,made in Athol Ma USA for over 100 years. I use it rebuilding boxes, rear brg's, differentials, rotor runout, machine tool repair and setup. Probably over $100 but worth it.
I do like to keep those chinese ones on the bench, great for killing flies.
Old Jan 19, 2008 | 11:02 PM
stock76's Avatar
stock76
Search eBay in the automotive tools section and the regular tools section. I recently got a Central Tools, made in USA, set with magnetic base and all attachments in a nice plastic case for around forty bucks. It was like brand new. I have also seen Snap-on sets. Same as the Central Tools but in a red plastic case instead of blue, and usually twice the price. Starret are outstanding gauges and show up on eBay as well. You can also find Matco and Mac tools sets. All are good professional grade instruments and sets and made in the USA.
If you want an inexpensive set, go to Harbor Freight.
Old Jan 20, 2008 | 12:42 AM
MotorHead's Avatar
MotorHead
It is true the cheap ones probably won't last as long, but they are accurate that is the main thing. I have cheap Chinese mics ( 1/10,000" ) and I checked them against high dollar mics and they were bang on.
Same with my bore gauge and dial indicators. I use these tools once or twice a year so they serve me well, if I were setting up rear ends on a regular basis I would buy more expensive measuring tools
Old Jan 20, 2008 | 01:34 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
For someone who does a lot of work with a specific tool, the expensive versions are often a good investment. For someone like me who just needs to check a rotor for runout or something of that sort every now and then, the Chinese thing does just fine.
Old Jan 20, 2008 | 09:17 AM
GTR1999's Avatar
GTR1999
I agree on the usage just watch them, all the ones I used(3-4) all started to stick,seem to have lost the spring tension to return the needle. I first noticed it checking backlash and the range changed .005 over 360* of rotation then I found it was the indicator.
I also have to admit I'm very biased against china,India, and Mexico in respect to where the US mfg has gone. I'm amazed just how many americans don't realize it but just about everything we have now is made elsewhere. We're losing experience every day as the older generation dies out.
Old Jan 20, 2008 | 09:56 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
occasional use Chinese is fine, just check their calibration every now and then. I kept getting different readings and had to double check with gap gauges. Measure twice.....
Also, try and get one that comes with a case to keep it from getting banged around too much.
Old Jan 20, 2008 | 09:21 PM
Thanks for all the great information everyone. For those that are using the Starrett and or Mititoyo, any specific model # you recomend?
Old Jan 20, 2008 | 09:39 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
tools that I use alot I spend the extra for good tools. But something I might use once or twice, I don't care about brand name just price. I do have Starrett and Mititoyo gauges also, but when I needed a second dial indicator I got a cheap one and it worked the same as the Mititoyo.
Old Jan 21, 2008 | 01:33 AM
MotorHead's Avatar
MotorHead
I agree with the China syndrome, everything is made there, if you look around your house probably 75% of your belonging are made in China. When I was a kid it was exactly the same except it was Japan now look at what happened there.
They have cities devoted to making ties, another one for making shirts, I am not kidding. Probably most clothes, furniture, electronics, car parts etc. etc. etc. sold in North America are being made in China these days
Everyone in NA thinks they should make 100K no matter what they do, and you can't compete with a country where they make a couple of bucks a day.
What Canada and States are going to become are distributors, not manufacturing anything anymore just selling it and I don't think this is a good thing
Old Jan 21, 2008 | 03:17 AM
Bowerss2's Avatar
Bowerss2
I have had increadably good luck with Starrett. Made in USA. I use them very frequently so i need the quality. In all honstly if you are only going to use it every now and again a cheepo will do just fine. Just check the calabration, even when it is brand new.
Old Jan 21, 2008 | 07:07 AM
stingr69's Avatar
stingr69
Harbour Freight has some in a display case near where I live. I have a magnetic base, dial indicator and even a decent caliper from them. If all you do is degree your cam with it once a year then by all means save the bucks and buy an inexpensive one there. Maybe $20 each.
-Mark.
Old Jan 21, 2008 | 08:38 AM
Gordonm's Avatar
Gordonm
Check out fleabay. I was just over there looking at the indicators. There are some decent Starrett ones for a good price. I like the 1 inch travel .001 increment ones for automotive work. It has served me well for many years.
To Dial Indicators
Old Jan 21, 2008 | 09:00 AM
I was thinking Ebay also Gordonm, but do to the vast selection I was hoping to narrow it down to certain specific models.
Old Jan 21, 2008 | 10:43 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
I've had both cheapo's and a very nice Mitutoyo set up. While they both work, the expensive ones are nicer to use.
Something to keep in mind is how much it hurts when the high dollar one hits the floor accidently.
Old Jan 21, 2008 | 11:46 AM
pws69's Avatar
pws69
I buy them from Grizzly.com - they seem to have "better" quality Chinese imports!
