Help!!!
I don't know what your emissions laws allow in AL, but if you can, I HIGHLY recommended switching your '80 to full length headers ahd true dual exhaust with custom bent pipes, with or without catalytic converters, and high flow mufflers. That heads-back system made a HUGE performance difference on my '80. I made a small modification to the front cross member to get some ground clearance on the driver side.
Here are some pics of my setup:
As for the exhaust, if you can get away with the full length headers and dual exhaust, by all means, do it. Don't do it without a balance pipe (H-pipe) or an X-Pipe.
