Garage heater question
Old Jan 21, 2008 | 03:43 PM
Gordonm's Avatar
Gordonm
Default Garage heater question
I bought myself a small electric garage heater. I think about 13,000 BTUs. Not looking to roast myself just bring it up to around 60 or so when it gets down real cold. My garage is attached and never goes below freezing. My question is where to put it. Should it be mounted closer to the floor to allow the heat to rise or up near the ceiling. My ceiling is 10'6" in a approx. 20X22 garage.
Old Jan 21, 2008 | 03:48 PM
Mia's Avatar
Mia
First as far as mounting, RTFM first.. Generally, they should be about 13" from the wall and ceiling. Best bet, read the instructions that came with it.
I found that centrally mounting mine so that it blows down and out towards the door opening was the best place. I get good air flow and decent heat throughout. You could try corner mounting, also a good choice. I had a TV in the corner so that killed that idea.
BTW, mine is 17,000 BTW, 30AMP Double pull 240v... Looks small, but with temps under 0 degrees this weekend, kept me a toasty 70 degrees!
Let me know if you have any other questions.
eastltd's Avatar
eastltd
That unit may be a little on the small size. I have a 90,000 BTU gas heater hung from the ceiling in a 24 X 28 garage. I have the T'Stat set at 68 and the unit comes on often in the winter months.
Old Jan 21, 2008 | 03:49 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Gordonm,
Most I've seen are close to the ceiling or midway above a workbench.
Old Jan 21, 2008 | 03:50 PM
hotshot79's Avatar
hotshot79
well, unless you are 9ft. 6 in. you won't notice the warmth as much down at car level as you do at the ceiling. heat rises, so, I would mount it at floor level . Do you have insulated doors on your garage?. You might be hard pressed to get the temp in the 60's but 50-55 is pretty comfortable working conditions, as the heat gets rid of the cold dampness of the concrete floor.
Old Jan 21, 2008 | 03:55 PM
spedaleden's Avatar
spedaleden
Here's mine
I have mine in upper left of picture and it points to center of garage, so air moves throughout the whole area.
As stated above the floor is really cold when your laying on it to work on the car. I usually throw a blanket down.
Gordonm you may want to go with to small units 1 low 1 midway
Old Jan 21, 2008 | 03:59 PM
Mia's Avatar
Mia
You'd be surprised how well these little electric heaters work... I should have stated, my 17k btu is in a 20 x 20.. Keeps things quite warm..
Old Jan 21, 2008 | 04:15 PM
Maymyvetteliveforevr's Avatar
I think a couple of important thing you should keep in mind.
The outside temperature
How well insulated your garage is Gordonm.
Old Jan 21, 2008 | 04:27 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I would place an electrical heater well off the floor....if it were me I would hang it from the ceiling.
Pic of my gas fired heater.
Old Jan 21, 2008 | 04:33 PM
Glass Act's Avatar
Glass Act
Mia, I had one and they do keep the chill out, but it takes awhile. I gave up and went with a 90.000 btu gas furnace, instant heat in 5 or 10 minutes in my 24X30 insulated garage.
Old Jan 21, 2008 | 04:35 PM
Gordonm's Avatar
Gordonm
That was a lot of info real quick. My garage is pretty well insulated. The doors are insulated but not great. I do not have to lay on the cold concrete anymore due to my new lift just installed. I am just really looking to knock down the chill on the coldest days. On a day that it is 45 with no heat in the garage it will be 50 to 55 in the garage. Today it is about 15 to 20 out and it is 38 in the garage, little too chilly. I would like to see about 55 to 60. I can work very comfortably in those temps. It is small enough I might try a few different locations before mounting it up. Two of my garage walls are right against living space so I do get some heat from the house, that is why it never freezes in the garage.
Old Jan 21, 2008 | 05:46 PM
Mia's Avatar
Mia
Good advice... Aside from the walls, having good insulation in your ceiling and at the very least, having that void enclosed is going to help greatly as well.
Understood... So long as it is above freezing, it is instant gratification for me. At the sub zero temps yesterday it probably took 1/2 hour or so to get it comfortable.. It keeps up just fine, and I credit the extra work/care I took in insulating in helping.
For your doors, just buy pink foam insulation, the rigid stuff. I bought 4 4x8 sheets of the 1 1/2" thick variety and cut it to fit in between each panel. You would be amazed at the difference that $50 or so made.
Laying on a cold floor is not the problem. No matter how warm you get it, your feet will get pretty cold. Next time around I am going with a heated floor.. You'd be surprised how much heat loss you have just in the concrete floor alone. I think you will easily see 55-60 with that unit.. That is enough to take the bite off! Anyway, I am glad I went with the larger unit because it does more than take the bite off.. It makes it darn comfortable out there! With the TV, Internet, Laptop, and a Gladiator fridge, all I really lack is a bed and shower. I could live in the garage!
Old Jan 21, 2008 | 07:23 PM
JPhil's Avatar
JPhil
Don't mount it too close to the floor--it can ignite vapors. The Code is 18" but even that seems a bit close to me. I'd mount it high, it's easier to keep it out of the way & reduces the risk of someting flammable coming in contact with it.
Does it have a fan? If not, get a small reciprocating tabletop fan and mount it upside down on the ceiling to circulate air.
Old Jan 22, 2008 | 04:52 AM
hunt4cleanair's Avatar
hunt4cleanair
Nice garage but tell us about the checkerboard on the wall. Tile or paint? And I'm curious why you've got lightbulbs next to those 18' flourecents?
Old Jan 22, 2008 | 09:33 AM
Mia's Avatar
Mia
They are th vinyl sticky back tiles.
The "light bulbs" are actually fluorescent as well. They were there first. I wired the cold weather 8 footers off of them. BTW, I've already replaced one of the "cold weather" ballasts after 5 years.. I would say they are still not immune from the cold!
Old Jan 22, 2008 | 10:40 AM
SIXFOOTER's Avatar
SIXFOOTER
Whats a Heater?
Old Jan 22, 2008 | 11:31 AM
Gordonm's Avatar
Gordonm
Originally Posted by SIXFOOTER
Whats a Heater?
Just the opposite of an air conditioner.
To Garage heater question
Old Jan 22, 2008 | 11:45 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Curious what that unit costs ? are you happy with it ? how many BTU's ?
I'll be using gas as well i assume it's cheaper then electric........?
any dangers with this unit in the garage to worry about ?
GAS vs ELECTRIC ?
Old Jan 22, 2008 | 12:27 PM
gq82's Avatar
gq82
GAS vs ELECTRIC ?
Very happy with it....heats the garage quickly. It's a 45,000 btu natural gas fired unit. More than enough to heat a 2 car garage.
Total cost was aprox $1800. A lot of this was labor/material for running the gas line to the garage (major project) and venting through the roof. Depending on your setup (access to gas line) it might be cheaper.
I've been told by friends in the business that this is the safest type heater (no standing pilot light, solid state ign, power venting) and certainly cheaper to operate vs. electric.
Old Jan 22, 2008 | 02:11 PM
Jay-Dog's Avatar
Jay-Dog
You stated that you bought an electric heater and not a gas heater correct? Electric heaters are radiant. They heat objects and not air. Think of it like the warmth from the sun. Most of the replies are regarding gas furnaces, which are convection heaters. They heat air. Heat does not rise. Warm air does. You should mount your electric heater as recommended in the instruction manual. Igniting fumes is not an issue with a radiant electric heater. It is, however a major issue with standing pilot gas units and wood burning appliances. You will probably find that it will heat best relative to where you are and the items you are working on. So, mount it near where you anticipate working. Maybe around the bench? If it were me, I would only turn it on when I'm in the garage. If you want something to keep temps up all the time, you might want to go with a gas powered suspended furnace. If you plan to open and close your garage doors frequently, warm air will easily escape. That's why many shops use ceramic heat tubes that reflect radiant heat down to the work space. That heat energy is easier to contain when doors are opened. By the way, if you are on LP gas, LP is heavier than air, and unburned LP gas presents more of a danger in your garage than natural gas. Good luck.
Jay
