i know this is a stupid question but what size is the orginial air cleaner for the carb like 10" or so reason i ask is because i got a little rickty small one and it looks outta place
Stock probably had a snorkel or two. None were round open element from the factory.
ah ok so i guess my next question would what is a good size air element that would fit on the car and what is a drop bottom? i think thats what its called
I think 14" is a common size to get and they are usually sold in a kit, with the base, lid, and a filter that matches the size.
You'll want to check your hood clearance before buying the filter because the elements come in varying heights.
This pic shows what a drop base air cleaner looks like. It 'drops' the base so when the filter and lit are on it they are not much higher than the carb for when clearance is tight.
I replaced my cast iron intake for a higher profile one and new carb. I needed to get a narrower air filter for clearance and a smaller diameter filter as the new carb was set farther back. If you want my old one for $20 shipped, PM me, good luck.
