T-top Molding kit
Old Jan 21, 2008 | 05:48 PM
Mia's Avatar
Mia
Default T-top Molding kit
Anyone ever use these? http://www.mamotorworks.com/corvette?frame=4.3925
They look like a nicer/easier to install and cleaner look as an alternative to the original trim.
I was having a hell of a time finding stock replacement trim, and heard that it is a bitch to install. I'm having the T's painted presently and figured this might be a better way to go.
Anyone out there use this? Opinions? Thank youl
Old Jan 21, 2008 | 08:27 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
I was thinking of doing the same ones. Curious if anyone else used these as well. The only thing I see that might look a little off is that they look kind of dull as compared to the stock ones
Old Jan 21, 2008 | 10:45 PM
Mia's Avatar
Mia
Anything is going to be better than what I had. The stock ones were dull enough as it is..
Old Mar 11, 2008 | 06:50 PM
Mia's Avatar
Mia
FYI, BEWARE.. These are not for the Fiberglass Tops like their catalog and web site says. They are for glass t-tops only.
I have to return mine... ARGH..
Does anyone know where to find the right trim/molding for the fiberglass tops?
Old Mar 11, 2008 | 08:57 PM
swtato's Avatar
swtato
St. Jude Donor '05
What will you take for the ones you got? Are they charging a restock fee?
Old Mar 11, 2008 | 09:15 PM
markbett's Avatar
markbett
I had to re-do mine and I purchased used T-tops off E-bay, took the molding off and re-used on mine. For the $35.00 for 1 top, it was worth it!
Old Mar 11, 2008 | 10:25 PM
temvette72's Avatar
temvette72
Zip has the metal trim pieces listed in their catalog.
Temvette72
Old Mar 12, 2008 | 07:26 AM
1982CorvetteDude's Avatar
1982CorvetteDude
Here you go
http://www.ecklers.com/product.asp?p...dept%5Fid=1508
Old Mar 12, 2008 | 10:33 AM
Mia's Avatar
Mia
Only one problem. That says 1968 to 1976
I have a 1979
Temvette72
Who is Zip?
I thought about that, but the reason I took them off in the first place is they looked like ****.. Why would I want to put a used piece on something I spent a fortune on refinishing? Also, as I recall, they pretty much get destroyed pulling them off... It was no easy task removing them. They were trashed when I finished getting them off.
No idea on the restocking fee... I paid $49.95 for them and would part with them for exactly $50 and I would front the shipping.. I assume that would save you some bucks. Comes with the adhesive too.
Let me know.
Old Mar 12, 2008 | 10:55 AM
1982CorvetteDude
I have a 1979
Shouldn't matter, the only real difference is the finish...the older ones were polished stainless steel and the later ones were painted trim black
I bought some stainless front pieces from an older corvette and it fit my 78-82 fiberglass tops just fine....I painted them black to match the rest of the car.
Old Mar 12, 2008 | 11:17 AM
Mia's Avatar
Mia
Cool, thank you! Ok, if that is the only difference, ie the finish, I guess I will go the Ecklers route.. Friggin expensive.. I should have just bought some new glass T's at this rate.
I figure I am about $250 on the paint, 12 hours sweat equity, $80 on the Weather Strip, $40 on the rebuild kit, and $72 on the pads if Wilcox ever gets them back in stock..
$442 + the trim, around $250 or close to $700... EEK..... I think I still may buy a Targa. I saw glass one pieces new for under $400 online.
Old Mar 14, 2008 | 01:15 PM
Mia's Avatar
Mia
Trying to order today, Ecklers seems to be having some trouble with their ordering system..
Just out of curiosity, was it hard to install the trim? My main concern is scratching the new paint job on the t-tops... How hard were they to install and did you have to use adhesive?
Thanks!
Old Mar 14, 2008 | 01:24 PM
1982CorvetteDude
Thanks!
It's not hard but you'll most likely scratch the paint sliding them on...try not to force them.
I used some of that windshield caulk (dum dum) to hold mine around the front.
But honestly on that it would have been better to install the trim prior to paint and then tape it off when you painted the tops.
Old Mar 14, 2008 | 01:30 PM
GD70's Avatar
GD70
Thanks!
In the AIM for my 70, it's called the drip moulding assembly and is installed using a sealing compound, 1/4" bead. It's visible at the ends on my t-tops and is black. It may be similar to yours. Look in your AIM if you have it, and get one if you don't.
Good luck, Glenn
Old Mar 14, 2008 | 01:33 PM
Mia's Avatar
Mia
Thanks guys.. Yeah, had I known first, I guess I would have left them on prior to paint. The paint guys suggested removing them, and to be honest, they looked like crap, so anything is going to be an improvement!
It's a learning experience!
Old Mar 14, 2008 | 03:42 PM
Mia's Avatar
Mia
Well, just ordered the parts, I guess we will see how it goes! Thanks again for the help!
Old Mar 14, 2008 | 03:44 PM
GD70's Avatar
GD70
Let us know how it goes.
To T-top Molding kit
Old Mar 20, 2008 | 02:13 PM
Mia's Avatar
Mia
Well my T-Top Trim arrived today from Ecklers. It is the stainless trim for the 68-76. Again, I have a 79', so gonna be fun seeing if it works.
One piece was on back order apparently.. Oh well..
So again, to bond the outer trim that is not screwed on, I should use a silicone adhesive? Anyone have any suggestions on what to use? Something simple and not too messy?
Thanks!!!
Old Mar 20, 2008 | 02:14 PM
Mia's Avatar
Mia
Good luck, Glenn
Any idea where to find this stuff? Thank you.
Old Mar 20, 2008 | 04:48 PM
Mia's Avatar
Mia
FYI to anyone else making this futile attempt at restoring T-Tops on a 7-82, the 68-76 DO NOT fit the 79!
While the outer trim might, the side trim that goes along the outer under sides does NOT. It's not even close.
I'm going to have to jury rig something or custom fab the piece at this point.
