'82 Exhaust question
Old Jan 23, 2008 | 11:39 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default '82 Exhaust question
Does the '82 exhaust have the heat riser on the passenger side?
I have a set of manifolds for an '82 to put on my car. I am thinking about buying an exhaust kit from one of the vendors. I just wanted to know if the passenger side tube would connect directly to the exhaust manifold or if it would have a gap where the heat riser is located on earlier models.
Old Jan 24, 2008 | 08:01 AM
jdp6000's Avatar
jdp6000
Heat riser is on the driverside. Goes to the intake. Are you maybe thinking of the the tubes for the smog stuff?
Jim
Old Jan 24, 2008 | 10:55 AM
Ak. Mal's Avatar
Ak. Mal
I was thinking of the valve that bolts in between the exhaust manifold and the exhaust pipe.
THis is the part I'm referring to.
Old Jan 24, 2008 | 11:55 AM
mr nasty's Avatar
mr nasty
My 82 has like factory headers and not cast iron exhaust manifolds. Do you have the cast iron manifolds?
Old Jan 24, 2008 | 11:58 AM
Ak. Mal's Avatar
Ak. Mal
I have a set of manifolds from an '84, but they are the same as the '82 exhaust manifolds.
I'm wanting to buy ah exhaust kit, but I want to know if one of the risers will be too short to connect to the exhaust manifold because there is supposed to be a valve in place.
Old Jan 27, 2008 | 10:11 PM
markcaro's Avatar
markcaro
Cruising
The 82 vette has fuel injection and there is no need for a heat riser to heat the underside of the intake. As for my recolection I don't remember an 82 vette having a heat riser. Hope this helps you.
Old Jan 28, 2008 | 10:28 AM
jdp6000's Avatar
jdp6000
82's do not have that.
Jim
To '82 Exhaust question
