68 Matching numbers
Old Jan 24, 2008 | 10:53 PM
DougDawg's Avatar
DougDawg
Default 68 Matching numbers
I am trying to run the matching numbers on my 68. I have found and verified all of them except the auto trans number. Can anyone tell me where to find the number?
Old Jan 25, 2008 | 12:11 AM
early shark's Avatar
early shark
dougandkay,
You should see a 'credit card' size metal plate with rivet in the center attaching it to the exterior housing. This metal plate will be silk screened with large and small letters. It will also have some stamped in digits also. This gives you the model ID of your TH400 and sequence #.
You will also have a stamped in derivative of your VIN to identify it as belonging to your specific car.
Old Jan 25, 2008 | 07:47 AM
DougDawg's Avatar
DougDawg
Thanks for the help. I'll try to find it. I'ts the last piece of the puzzle.
Old Jan 25, 2008 | 07:57 AM
Deron's Avatar
Deron
Here is a pic of where I found my vin stamp. maybe it will help.
[IMG][/IMG]
Old Jan 25, 2008 | 09:55 AM
halfmoontrail's Avatar
halfmoontrail
The VIN derivative will be on the driver's side, machined flat plate just above the pan (as shown).
The other poster was also correct about the data plate, it will be on the passenger side. Can be helpful for "matching numbers" IF you have the P.O.P.
Steve
Old Jan 25, 2008 | 10:21 PM
DougDawg's Avatar
DougDawg
Default Thanks All
I just want to thank you all for going to the trouble to help me. I have had my Vett for 5 years but I only recently became associated with the forum. It's so cool to know that when you have a question or problem that people in different states that you will probably never meet come together to help.
To 68 Matching numbers
