Header Gasket failure...again
Old Jan 25, 2008 | 12:23 AM
Vette80regon's Avatar
Vette80regon
Default Header Gasket failure...again
Shoot.
What header gaskets will last more than 3 or 4 months?
*I have used the regular ol' felpro type gaskets (2 months)
*I have twice used the thicker 1/4 inchers... (3 to 4 months)
*Lastly, I used the thick softer graphite (expensive ones) and am hearing the tell-tale "peck peck" exhaust leak sound. Sure enough, the gasket on the pass. side front of the engine is squishing out...d@mn...
How long do your header gaskets last? Am I over tightening them?
I am using the 3/8 box end wrench so I can't be doing it too tight can I?
Old Jan 25, 2008 | 01:05 AM
yellow94coupe's Avatar
yellow94coupe
Have you thought of trying a copper gasket? It seems like that would be pretty durable.
Old Jan 25, 2008 | 07:17 AM
buffed1978's Avatar
buffed1978
Default Copper Header Gaskets the only way to go
I changed the gaskets on my headers over to copper gaskets and have never had a problem with them.They cost a little more but well worth it.
Old Jan 25, 2008 | 07:50 AM
Vette Crazzy's Avatar
Vette Crazzy
copper ones are best. be sure after you install them, get the car to oper temp, shut it off and retighten. and every couple weeks check the bolts to make sure they don;t loosen
vc
Old Jan 25, 2008 | 08:33 AM
Durango_Boy's Avatar
Durango_Boy
Have you checked to make sure the header flanges are perfectly flat and free of defects? Also, run a T-square over the flange mating surface on the heads and check to make sure it'll all perfectly flat.
How thick is the header flange?
Old Jan 25, 2008 | 08:49 AM
Gordonm's Avatar
Gordonm
I have used the standard Fel Pro gaskets with Permatex high temp sealant for years. I have taken the headers off a few times and reused the gaskets with no new sealer and they are still not leaking. I use copper gaskets at the collecters. I swear by the high temp Permatex. A local speed shop told me to try this a few years ago and it has worked very well. Coat both sides and let it set up before firing the motor. Retighten the headers after heating up. Do this a few times and you should be OK.
Old Jan 25, 2008 | 09:28 AM
rihwoods's Avatar
rihwoods
Solved my issue with copper gaskets...my flange on pass side slightly off,but the copper fixed it....
Old Jan 25, 2008 | 01:20 PM
halfmoontrail's Avatar
halfmoontrail
On my street rod ('36 Ford w/Chevy small block) custom headers, I use 2 of the cheap Mr. Gasket "paper" header gaskets on each side, stacked.
Works great.
Steve
Old Jan 25, 2008 | 01:34 PM
outlawkinser's Avatar
outlawkinser
Default Header Gaskets
I used these when I rebuilt the engine several years ago and have not had a leak!
Mr. Gasket 7153 - Mr. Gasket CopperSEAL Exhaust Gasket
Embossed Solid Copper
Embossed O-ring gasket design increases sealing pressure around exhaust ports to create a tight, leakproof seal, even on irregular surfaces. Made from long lasting .043” solid copper, these gaskets will not shrink, deteriorate or blowout, so gasket leaks are eliminated!
Bought them from Jegs.
Old Jan 25, 2008 | 01:44 PM
69autoXr's Avatar
69autoXr
Many times the gaskets fail because the bolts loosen. Have you found any loose bolts? With my old 1-5/8" primary headers, I was able to use lock washers on my bolts and I never had a gasket failure, and I'm not using any type of copper gaskets, just your typical FelPro's. With my newer 1-3/4" headers, I had to use high-collar lock washers but my bolts are still tight...
Old Jan 25, 2008 | 01:48 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Copper here also, as stated though, you must check every so often to be sure they stay tight.
Old Jan 25, 2008 | 04:20 PM
outlawkinser
Default Header Bolts
I used Stage 8 Locking Header Bolts along with the Copper Gaskets. No leaks and the bolts don't loosen!
Old Jan 25, 2008 | 07:57 PM
jdmick's Avatar
jdmick
Same setup here and no problems after 3 years and many miles. Do it right and be done with it.
Old Jan 25, 2008 | 08:00 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
anyone tried the aluminum type gaskets?
Old Jan 25, 2008 | 08:22 PM
jdmick's Avatar
jdmick
I used the Earl's "pressure master" gaskets that use soft aluminum inserts, not copper, on my Hooker sidepipe headers. I think the Percy's "dead soft" are pretty similar. Either one will compensate somewhat for an untrue flange.
Old Jan 25, 2008 | 11:56 PM
Vette80regon
Thanks fellas,
After every header gasket change (now that I have done it, many many times :P) ) I make sure that I run it, retighten, run it 50 miles, retighten. Run it 1 week, retighten. and many many variations of re-tightenings inbetween those times too.
Thank you for the Jegs link. I guess I'll buy the copper ones now.
Fortunately they aren't as much $ as the graphite ones were
I have the Stans TriY headers. Very thick flange [Headers have 16 gage tubes and 3/8" thick flange].
. Very very true and no need to run a Tsquare on them, As they were true when I put them on.
I think...(he he he) That the stock heads have square ports and the headers are circular/round ports. I am unsure what gaskets to buy...a round port gasket or a square port gasket...
Any tips?:
Gordon, been autoXing recently?
To Header Gasket failure...again
