Body Mount Shims
Old Jan 25, 2008 | 01:09 PM
1974slcvette's Avatar
1974slcvette
Default Body Mount Shims
When I recently changed my body mounts there were no shims present on any of the mount points. I this a cause for concern? Mounts had never been replaced when I tackle them....
Old Jan 25, 2008 | 01:19 PM
Durango_Boy's Avatar
Durango_Boy
It's only a concern if the body lines do not match up properly after the body mounts are replaced. Once they are installed, and you can see gaps and lines you can determine if you need a shim to correct any problems.
Old Jan 25, 2008 | 01:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If they weren't there, it sounds like the factory actually lined things up right the first time. I only had shims on one #4 mount - the rest were clear.
Old Jan 25, 2008 | 02:43 PM
1974slcvette
Thanks for the input, I'll check the body lines when I get home. Just for clarification DB, do you mean the door and hood seams?
Old Jan 25, 2008 | 03:37 PM
Durango_Boy
Yep. The front fenders play a big role in hood and door fitment, as well as the rear clip and the doors.
Old Jan 25, 2008 | 03:47 PM
1974slcvette
Thanks DB, I'll check when I get home!
To Body Mount Shims
