I found a switch mounted on a clip like the one that holds the door lock cylinder on place the switch body is white with two spade terminals coming out along with what looks like a plastic (part of the switch body) tab which looks like the connector locks in place it was behind and under the glove box loose just lying there not connected any clue as to what it is.its in a 78
I'm not too familiar with the electricals on the later models. The general area you describe is where the turn signal flasher is located I think.
See if you get some more feedback. In the meantime have a look at this: http://www.corvetteforum.net/c3/tune...l/index6.shtml It may be something you would want to save in your bookmarks for further reference.
Wish I could be more help.
duke 94 yes thats it, your a genius, ok my next question where can i find a replacement and you see where the wires looks like yellow and blue its an alarm switch key activated where can i find two of those. thanks a million. and where did you find that picture i have been looking everywhere for illustrations like that of the door. and goinbroke thanks for that electrical layout boy is that going to come in handy. artsvette73 you also were right on just by the discription all you guys are awesome thanks again
