power door locks
Old Jan 29, 2008 | 06:31 PM
ubowl's Avatar
ubowl
Default power door locks
Iam trying to install power door locks in a 78. None ever there is there a harness i can get to make this easy or is there a kit or something, if some one thats done it has any pointers
Old Jan 29, 2008 | 06:50 PM
spedaleden's Avatar
spedaleden
Part of the door lock harness in built into the main harness that runs in the car. I would buy the harness the plugs into the back of the door lock switches. From there I would make my own harness. I will try to post a pic of the factory wiring. Just make the same harness and it should work.
The diagram is here. Print it. I would run at least 12 guage wire with good jacket
http://forums.corvetteforum.com/show...or+lock+wiring
Old Jan 29, 2008 | 06:58 PM
SIXFOOTER's Avatar
SIXFOOTER
That would be the way to go,
Here is a schematic
As you can see the part that is inside the car is only 3 wires plus a run to the fuse block
Old Jan 29, 2008 | 08:38 PM
ubowl's Avatar
ubowl
ok must be dumb i know it says they go to theft deterrent system but where and thanks for the help i really appreciate this
Old Jan 29, 2008 | 10:28 PM
spedaleden's Avatar
spedaleden
I would get the locks working and then worry about the security system or don't even connect to the security system
Old Jan 30, 2008 | 12:15 AM
SIXFOOTER's Avatar
SIXFOOTER
That refers to the stock 81 Theft Deterant system. If oyu try to unlock the doors from the inside with the door locked by the key,, the alarm will sound.
Old Jan 30, 2008 | 08:22 AM
ubowl's Avatar
ubowl
well if the factory wiring works both theres got to be a way. I will try to figure it out. electric troubleshooting is not my strong point but hopefully will figure it out. Thanks again
Old Jan 30, 2008 | 08:38 AM
spedaleden's Avatar
spedaleden
Power Door Lock (LH) Door
Gray - To Grey (LH) pin switch
Tan - To Tan (LH) pin switch
Orn - To 12 volts hot all the time
Power Door Lock (RH) Door
Gray - to theft module 3rd pin in from right side of module & Gray of LH door pin
Tan - Arm wire for theft module pin in from right side of module & Tan of LH door pin
The diagram is on page 8A-44 of the corvette shop manual
To power door locks
