air filter assembly
Old Feb 2, 2008 | 10:53 PM
doublearrow's Avatar
doublearrow
Default air filter assembly
Well today I did some learning. I replaced my points type accell distributor with an accel hei distributor. I started it up and nothing blew up. Now I have a problem. Before I had a 14" drop base air filter assembly on the car the distributor was so big it wouldn't fit. I bought a 9" air filter assembly that did not have a drop base and it's too tall. I'm not sure how much because I don't want to crack the hood. Any ideas or suggestions on what to do next? Any help is appreciated
Old Feb 2, 2008 | 11:25 PM
SEVNT6's Avatar
SEVNT6
Maybe try a '76 base? It has an indentation at the back that allows room for the HEI...
Old Feb 3, 2008 | 01:35 AM
doublearrow
WOuldn't by any chance have a picture would you? Can't seem to find one on ecklers or the other suppliers. I have an edelbrock intake and holly 4 barrel. I looked at the offset drop bases (14) but they said they will not fit a 4 barrel.
Old Feb 3, 2008 | 08:52 AM
marshrat99's Avatar
marshrat99
On my 79 L82 I'm running a Holley, EPS intake and HEI with a 3"x14" cleaner. Had to go with a dropbase, OFFSET clearner base. The offset part is that the carb opening in the base is moved off-center which allows the base to be positioned farther foward and away from the HEI. This can be found at Summit or Jegs.
Old Feb 3, 2008 | 10:26 AM
doublearrow
Thanks for the help guys. You don't by chance have a part number on the drop offset air filter base? I found several on both sites and they all say they don't fit holley 4 barrels. I did find one that doesn't say what it fits at all. Thanks Ryan
Old Feb 3, 2008 | 10:57 AM
SteveG75's Avatar
SteveG75
I am using a Moroso Low-Profile Racing Aircleaner. 14"x3" and it just touchs the HEI. I have a Q-Jet on an Edelbrock RPM manifold.
A lower intake might cause the clearance to be tighter.
Unfortunately, a dropped offset base will not work with a Holley or Demon due to the fuel bowls. Moroso has an offset base but it only works with Holley 2bbls due to the fuel bow issue.
To air filter assembly
