Starting interior resto. on 79
As for the rear carpet, it is not glued, the carpet has a plastic rail attatched to it with slides right into the rear of the car.
The rear carpet is on a formed lip at the rear under the shade.It will lift off the rail and come right out.
I just completed a COMPLETE REDO of my 79E interior due to age,excessive weight in the drivers seat,water damage,and driver's cigar damage.
The only thing I didn't replace in the interior was the steering column.
Good luck with it and ask if you need any info.Don't be surprised at 3k in expense if you have water leaks......
START with a 12 to 24 inch extension on your ratchet.
Slide both seats back as far as possible remove bolts exposed, then slide forward as far as possible.
Do the same for the bolts that the extension is too long to use on....it really is as easy as "just removing 8 bolts".
Also; tag and bag all interior screws/nuts and bolts...label them as to where they came from....take pictures of your progress....not just to show us, but, to remember how things go back together.
And if you need some interior parts, let me know...I have some new stuff left-over from when I restored mine....I am talking brand new!
ie; window felt, door seals, t-top gaskets, windshield wiper switch, emblems, all the way to engine parts, ie; Accell super coil and HP plug wires, radiator gaskets, dual snorkle parts, brand new GM hood felt, ect...
Yeah...I got a ton of new and perfectly good used stuff for a 79 L82, just been too much hunting to take pics and put in the for sale section....but I will sometime after Mardis Gras.
G/L and take your time.
Jim
DEFINETLY BAG AND TAG TAKE DIGITAL PICS FOR QUICK REVIEW. I DID THIS MYSELF ALSO (WELL WITH A LITTLE HELP FROM A FRIEND WHEN IT CAME TO THE DASH AND ELECTRICAL) DOOR PANELS WERE DONE BY A SHOP. (I DIDNT WANT TO SCREW THAT UP $$$$) I DID A COLOR CHANGE ALSO. FROM RED TO DOESKIN
BIG
