Headlamp adjuster bracket (73 vert)
Old Feb 4, 2008 | 03:02 AM
jjl's Avatar
jjl
Default Headlamp bracket (73 vert) - Can it be welded
One of my headlamp brackets (the large part that hold the headlamp cover and the actuator) has the two front ends broken off. The bracket is some type of cast aluminum. I have the broken pieces. Can they be welded back on successfully or should I buy a new bracket (expensive).
Jeremy
Old Feb 4, 2008 | 08:10 AM
babylonvette's Avatar
babylonvette
any quality welding shop that does alunium does it ,i have a friend that has a motorcycle shop that does my alunium welding just ask arround and yes they brake during front end accidents so it is common , i by up the broken ones then have them repaired ,not everone has 3/4 hundred for a new pair
