Plug Wire Route
Old Feb 5, 2008 | 09:08 PM
marines's Avatar
marines
Default Plug Wire Route
Being new to C3's I am sort of a loss figuring out the pathways for plugwires. It appears that they run down the backside of the engine and then along the side. Is this true? Is there a diagram showing the route of the wires? Also, my 74 has an electronic ignition. Does it also have a rotor within the distributor? My problem is that there is a small miss when idling and upon acceleration. If I accelerate hard the miss disappears until I once again idle or slow the vehicle. I am thinking of replacing the plugs, wires, distributor car, and rotor. Any help would be appreciated.
Old Feb 5, 2008 | 09:36 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
See this thread on the same subject i posted last week. Hope this helps. Its basic things like replacing caps rotor plugs and wires that can make a big difference in how the motor runs.
http://forums.corvetteforum.com/show....php?t=1929146
Old Feb 5, 2008 | 09:45 PM
gofastvette's Avatar
gofastvette
Before you buy anything read your plugs.This is the only clue as to what is happening in the cylinders. Identify the bad cylinder or cylinders and then take the necessary steps to fix it.
Old Feb 5, 2008 | 11:09 PM
Scott Marzahl's Avatar
Scott Marzahl
Wire routing can be found in the Assembly Instruction Manual (AIM). Yor miss sounds more like a carb problem or possibly a vacuum leak.
Old Feb 6, 2008 | 01:57 AM
marines's Avatar
marines
Thanks, Guys
I ordered an A.I.M. manual this week and hopefully it will get here by the weekend. Looks like an involved job replacing the wires! Since it is a new carb (Edlebrock), it may need adjustment. Thanks for the reference and the pointers.
To Plug Wire Route
