t top question
Old Feb 8, 2008 | 09:38 PM
NBC3's Avatar
NBC3
Default t top question
Will the t tops of a 79 fit on a 76?? if not is it a simple mod? or not worth the bother?
Bill
Old Feb 9, 2008 | 01:10 PM
NBC3's Avatar
NBC3
self bump
Old Feb 9, 2008 | 05:02 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
The tops on your 76 have two levers to lock them down. The 79 tops have one lever that moves a pin on the end to lock the rear of the top down.
To make the 79 tops work you will need to remove the triangle bolt that goes into the roof halo so the pin can slide in.
Old Feb 9, 2008 | 05:17 PM
NBC3's Avatar
NBC3
Is removing this bolt a major production? Also can you please explain further as to what the roof halo is? My car is in storage and as such I cant check to see what you mean. Perhaps someone could post a pic of the t top mounts in a 76?
Old Feb 9, 2008 | 05:20 PM
NBC3's Avatar
NBC3
this is a pic of the tops
Old Feb 9, 2008 | 05:42 PM
donnd's Avatar
donnd
Ed ,pm me your phone # if you like and I may be able to explain the difference .It would be tuff to do typing. Don
To t top question
