A/C Under Pressure?
Old Feb 9, 2008 | 10:54 PM
Sidepiper's Avatar
Sidepiper
Default A/C Under Pressure?
I'm going to be removing my a/c compressor and hoses, system has not worked in 20 years. When I remove the hoses is r12 going to come flying out? I was reading that these systems are under alot of pressure. Thanks
Old Feb 9, 2008 | 11:11 PM
spedaleden's Avatar
spedaleden
If there is freon in the system, yes it is going to come out. BECAREFUL, freon is very cold and oil is going to come out also. If you have to do this, there are fittings in the lines a high and low. I would push down on the fitting (Looks like the filler for air on your tire) and see if there is any pressure there. You can release the pressure that way or you can release it by loosing the bolt on the back of the compressor. If you do this method remove the bolt very very slowly. Once you here the hissing just leave it alone until it stops.
EPA will hate you.
The bolt is were you see the large freon line going to the back of the compressor
Old Feb 10, 2008 | 02:50 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Please dont discharge the R12 out in open air! .. it will just widen the ozone empty spot more and more! .. By law, only certified discharge station would be allowed to do that.
Old Feb 10, 2008 | 02:54 PM
markdtn's Avatar
markdtn
You could be heavily fined if a neighbor saw you do that and turned you in.
Old Feb 10, 2008 | 03:02 PM
Artsvette73's Avatar
Artsvette73
But I would bet after 20yrs of the A/C not working. It's freon has made it well past the ozone layer
Old Feb 10, 2008 | 03:59 PM
Sidepiper's Avatar
Sidepiper
Thats what Im thinking, I would be suprised if anything is in there. The car is currently not running so I can't get it to a station. Has anyone out there disconnected the a/c where the freon was gone? Thanks for the responses
Old Feb 10, 2008 | 05:53 PM
tnovot's Avatar
tnovot
Default A/C pressure test
It is very easy to determine if your system still has pressure. Just take the cap off one of the schrader valves (looks like a valve stem) and give a quick push down on the center. You can use either the high pressure side (line goes to the condenser by the radiator) or the low pressure side (line goes to the evaporator by the heater core) if you have a fitting on each.
Keep your face and bare skin away just in case but I would also seriously doubt that you will have any pressure after all this time.
Terry
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
The valves are called Schrader valves. Get a set of gauges ( maybe the local auto parts store will loan you a set ) or have an HVAC guy stop out and just put his gauges on your line. He can then tell you if there is anything in there. If you are in good with a mechanic maybe he could stop out on his way home.
I agree: It is not cool to discharge R-12 into the air. Its the same as dumping oil down your drain.
Old Feb 10, 2008 | 05:58 PM
Sidepiper's Avatar
Sidepiper
OK, I checked the valves and no pressure at all came out. Is it safe to disconnnect the hoses now. Does no pressure mean no freon?
Old Feb 10, 2008 | 06:01 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
What about some of those air dusters in a can some contain r-12
Old Feb 10, 2008 | 06:59 PM
markdtn's Avatar
markdtn
Not in many years-like 15-20 I believe. Now they have compressed air in them.
Old Feb 10, 2008 | 07:30 PM
dak82ce's Avatar
dak82ce
Yes. Some of the lines or your condensor may still have some refrigerant oil. Just drain it off after removing.
You might save everything. At some point you or the next owner may want air conditioning.
Old Feb 10, 2008 | 11:10 PM
Sidepiper's Avatar
Sidepiper
Thanks, I save everything that comes off the car, for the next owner.
To A/C Under Pressure?
