Help finding a hole saw please.
Old Feb 10, 2008 | 02:47 PM
Durango_Boy's Avatar
Durango_Boy
Default Help finding a hole saw please.
I am looking for a 5-1/8" hole saw, bi-metal for cutting plastic, and I am having a hard time. I can find 5" and 5-1/4" but not in between.
Does anyone have or know where to obtain such an odd size? I have searched a lot of online companies that specialize in hole saws but I have had no luck.
This is for a project on my Corvette so it applies here in General.
Thanks.
Old Feb 10, 2008 | 02:54 PM
Artsvette73's Avatar
Artsvette73
If it's flat try this adjustable fly cutter
http://www.mcmaster.com/
Old Feb 10, 2008 | 02:56 PM
markdtn's Avatar
markdtn
Did you try McMaster Carr and Grainger? Might also try Greenlee tools that make electrical tools, they might make one.
Old Feb 10, 2008 | 03:23 PM
Durango_Boy
I did try McMaster and Grainger. No luck finding a 5-1/8" saw.
Thanks for the help so far.
Old Feb 10, 2008 | 03:26 PM
jdp6000's Avatar
jdp6000
Have you tried Lowes? I know they have some odd sizes. I was looking for a 3 1/4 for potlights and found it there. I seem to recall larger sizes up to 6 inches.
Old Feb 10, 2008 | 03:33 PM
Durango_Boy
Yep, I have tried Lowes, Home Depot, Ace Hardware, and a few local stores that specialize in tooling.
All have said they know the size exists but that it's not on any of their catalogs.
Old Feb 10, 2008 | 03:38 PM
Durango_Boy
Would the Metric version be 130mm or 131mm?
Old Feb 10, 2008 | 03:46 PM
speedreed8's Avatar
speedreed8
http://www.enforceronline.com/pdfsound/ha502.PDF
http://www.enforceronline.com/page18.htm
Old Feb 10, 2008 | 03:59 PM
SIXFOOTER's Avatar
SIXFOOTER
McMaster 8830A13
I have one of those and it does pretty good on flat stock. You can use it on Some odd shapes like a kick panel, but back it up on a piece of thick foam.
Use it in a drill press and go SLOW
Old Feb 10, 2008 | 04:07 PM
chris75stingray's Avatar
chris75stingray
5.125" = 130.175 mm
Old Feb 10, 2008 | 04:14 PM
Durango_Boy
Originally Posted by SIXFOOTER
McMaster 8830A13
I actually have one like that already but the stock is not flat, it's convex. I have to have a traditional style hole saw I think or it won't work.
Old Feb 10, 2008 | 04:21 PM
MN80Vette's Avatar
MN80Vette
I've had to cut odd-sized holes in foam cored fiberglass bulkheads. I used a rotory saw (like a RotoZip) and a 1/4" masonite tempate. The hole in the template was the radius of the hole I wanted plus the radius of the rotory saw base. This method allowed me to cut multiple holes the same size with smooth edges.
Old Feb 10, 2008 | 04:46 PM
onaqwst's Avatar
onaqwst
take a 5" hole saw and then a sanding drum....... if it's plastic you shouldnt have a problem............ can always try to spary mount some 80 grit sandpaper on the outside of the hole saw and hopefully it'll open up the hole more.....
b
Old Feb 10, 2008 | 05:01 PM
Durango_Boy
b
That would work perfectly except I need what comes out of the center...not what the hole is cut into.
Old Feb 10, 2008 | 05:10 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
Jigsaw then finish with sanding disc
Old Feb 10, 2008 | 06:01 PM
jdp6000's Avatar
jdp6000
I'll take a look up here over the next few days. Just so I understand you need a 5 1/8 hole saw. traditional type that goes on a drill. Right?
Jim
Old Feb 10, 2008 | 06:26 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Hey Matt - I believe GordonM works in that industry. Try PM'ing him. He might be able to direct you.
If I understand this correctly, you are looking for about a 5" core????
John
To Help finding a hole saw please.
Old Feb 10, 2008 | 06:28 PM
onaqwst's Avatar
onaqwst
cut it bigger then and sand it down...unless you are trying to plug something.......
Old Feb 10, 2008 | 08:25 PM
Durango_Boy
Jim
That's exactly right. Drill press mounting, but the material is not even and has to be cut with a tradition style hole saw.
John
Yes, I am looking for the core to be a perfect round 5" shape. That and the uneven surface s why I have not attempted to use a free hand saw of some kind, and that's why I don't want to use a 5-1/4" hole saw and sand it down from 5-1/8" to 5".
I'll try to contact Gordon about it. Thanks.
Old Feb 10, 2008 | 08:33 PM
73339's Avatar
73339
What are you using the cut out piece for?
