Found 77 build sheet!
Old Feb 10, 2008 | 09:53 PM
Dr Gas's Avatar
Dr Gas
Default Found 77 build sheet!
After looking for 2 months and giving up, I found my build sheet glued to the gas tank shroud. Still in good shap but the center is still glued to the shroud. Next step I might go ahead and drop tank and remove shroud to remove the rest.
Old Feb 10, 2008 | 11:30 PM
Sidepiper's Avatar
Sidepiper
Post Pics
Old Feb 10, 2008 | 11:53 PM
dabrogger's Avatar
dabrogger
can you tell me exactly how you found it i.e. where did you look from/through etc. i too have a 77 i'd like to find the build sheet on. good find!
Old Feb 11, 2008 | 01:21 AM
BackN70's Avatar
BackN70
The safest way to get the build sheet is to drop the gas tank. Some have also found a second build sheet upon removing the dash pad, but is less common.
Old Feb 11, 2008 | 03:33 AM
hunt4cleanair's Avatar
hunt4cleanair
Congrats! Sounds like you're removing it in pieces...be careful removing the balance. Best method I've read is to use a razor blade and cut the glue from the shroud.
Old Feb 11, 2008 | 07:20 AM
Durango_Boy's Avatar
Durango_Boy
There is a metal shroud bolted to the frame, so the tank has to come out and then the shroud has to come out. Once it's down, you'll see the sheet glued to the driver's side.
My paper was intact but the type was all worn away. I had a clean white piece of paper.
Old Feb 11, 2008 | 10:03 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
I always thought that the build sheet was on top of the fuel tank. I dropped my tank and had no luck finding it. DB are you saying that the sheet is inbetween the metal shroud and the fiberglass?
Old Feb 11, 2008 | 10:04 AM
Durango_Boy
Yep, they moved it to the top of that shroud in '77. I am also pretty sure that '77 is the only year to have that shroud.
Old Feb 11, 2008 | 10:44 AM
chstitans42
TheCorvetteBen
Oh it was just for 77. gotcha. ok now im not thinking about dropping my tank again
Old Feb 11, 2008 | 10:47 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I hope you took a picture of where you found it before you removed it.
Old Feb 11, 2008 | 12:24 PM
Dr Gas's Avatar
Dr Gas
I dropped the tank a few inches to look on top first. Then yesterday I doing more cleaning around the tank area and seen gravel caught behind the tank shield. Took the bolts out to clean and WOW!!! Stuck to the drivers side at the top was a paper. Hind sight I should had took my time and dropped the tank, remove the sheild and not get in a big hurry. But,, WOW! My Wife said I acted like Indiana Jones with the Corvette Holly Grail. If you have the tire carrier out and remove the bolts that hold the sheild in, you can look up the side and see the sheet if it's there.
Old Feb 11, 2008 | 12:35 PM
BKbroiler's Avatar
BKbroiler
The sheet was on top of the tank shroud on my 77 too. I'm glad I didn't go through all that trouble just to find the build sheet because it was completely faded out.
Old Feb 12, 2008 | 12:26 AM
MarkV's Avatar
MarkV
Actually, this is called a gas tank shield, not a shroud. Here's a few shots of what the build sheet looked like before removal from my '77's shield.
Old Feb 12, 2008 | 04:09 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
My 75 Convertible has that tank shroud would my tank sticker be in the same place?
Old Feb 12, 2008 | 04:15 PM
MarkV's Avatar
MarkV
Yes, I would bet $$$ that this is where your build sheet is. I am sure that they used this gas tank shield during the years 1975 thru 1977. There's no telling how many people have dropped their gas tanks & found no build sheet & put it all back together, never realising that their build sheet has been there all along, glued to the top of this tank shield....
To Found 77 build sheet!
