Ignition lock, or ignition switch ?
Mark
http://jimshea.corvettefaq.com/
Thanks, I'll check that out.
It may be doable with out removing the column.
My 71 did the same as yours , not knowing better I had the switch replaced and it still did the same thing.
There are 2 screws that hold the lower switch to the column.
A small mirror will help
As I recall they are 1/4 inch.
Loosen them and slide the switch toward the steering wheel about
1/4" and try the key.
Good luck
David
Good luck
David
Did you do that from underneath of the dash, or did you drop the steering column down first? Thanks!
I removed the column and when I did Iwent ahead and replaced the switch. Here's some pictures that I took. They may help you out...
http://s189.photobucket.com/albums/z...man2001_photo/
I removed the speedo/tach cluster, which I've done before, and loathed. The worst is yet to come, when I have to reattach the tach and speedo cables to the head. The tach especially, is such a pain to reattach. But, it will be worth it.footnote: after being on jackstands for 6 weeks, I took her out today for a test drive. I had my steering box rebuilt by Gary Ramadei (from this bbs) and it drives fantastic now!
to you Gary! Also, I had rebuilt my shifter. It shifts a lot tighter now, most of the slop is gone.
The testdrive did reveal a nagging, squeaking right rear rotor. Light application of the brakes makes it stop. I'll have to check the run-out on the rotor.
Thanks again everyone; this forum rocks
But after re assembly it appeared to be something that could be done while installed. But I did not try it.
David
The positions for your ignition key are as follows:
START, RUN, OFF, OFF-LOCK, & ACCESSORY.
You cannot get to OFF-LOCK unless that lower lever is all the way UP.
Some people disconnect the cable and wire the lower lever permanently in the UP position. Just be aware that with the lever always UP you can turn off the engine and lock the steering wheel even while driving down the road.
This address will take you to a paper on this interlock system with much more information.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
Jim
