Prebent stainless radiator hose
Old Feb 21, 2008 | 09:05 PM
vietvette 77's Avatar
vietvette 77
Default Prebent stainless radiator hose
With the two serious bends in the radiator hose on my '77' I have found it impossible to slip on one of the braided hose covers or get a stainless or high pressure hose to work well. Does anyone make a braided or stainless hose that is prebent like my original hose? Or is there one on the market that can form and hold the bends?
vietvette
Old Feb 22, 2008 | 06:45 AM
BigEarl's Avatar
BigEarl
bump
Old Feb 22, 2008 | 08:04 AM
KW's Avatar
KW
not sure if this is what your looking for
cool flex hose is solid copper can be cut
and shaped how you what it
i have a upper and lower
they are great
Old Feb 22, 2008 | 05:11 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Feb 22, 2008 | 05:53 PM
Binnie77's Avatar
Binnie77
I have a flexible stainless hose and it can be bent into any configuration.
Old Feb 22, 2008 | 07:41 PM
vetteguy75's Avatar
vetteguy75
I have the flexible stainless steel radiator hose, but I have seen prebent solid steel radiator hoses...where would you get those?
Old Feb 22, 2008 | 08:11 PM
Domer's Avatar
Domer
I too have a 77. It was difficult to put the braided cover on the existing rad hose, all the others were a piece of cake. Had to buy a new rad hose (which of course did not have the expansion in the rubber from use), used leather gloves, stretched out the 'bends' reasonablyt straight and used windex as a 'slippery agent'. It took some time (about 45min), but it worked and I now have a new rad hose with the braided cover. Take your time and it will work.
Good Luck
Domer
To Prebent stainless radiator hose
