Ecklers hood
Old Feb 24, 2008 | 04:01 PM
fauxrs2's Avatar
fauxrs2
Default Ecklers hood
Has anybody seen one of these hoods installed?
Old Feb 24, 2008 | 08:37 PM
MN80Vette's Avatar
MN80Vette
Is that the high rise hood? If so, I'd like to see how one looks too. I'm not a fan of the L88 hood. I don't remember seeing a grove or ridge in the high rise hood though.
I'm always fighting clearance problems. How much extra clearance does it provide.
Old Feb 24, 2008 | 11:41 PM
panic's Avatar
panic
Here is your Eckler's high rise hood with a stingray scoop on top...
Old Feb 24, 2008 | 11:44 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Looks like a C4 style rise on it. Looks pretty interesting.
Old Feb 24, 2008 | 11:53 PM
Buggs's Avatar
Buggs
I have an extra one of those around. Good clearance, not as good as the L88 - but quite a bit more then the SB version.
What do you want to know?
Old Feb 25, 2008 | 12:10 AM
TimAT's Avatar
TimAT
Is this the same hood??
Old Feb 25, 2008 | 01:24 AM
Bee Jay's Avatar
Bee Jay
How much you want for it?
Bee Jay
Old Feb 25, 2008 | 07:04 AM
MN80Vette's Avatar
MN80Vette
Originally Posted by fauxrs2
I don't think yours is the same as fauxrs2's or panic's. The transition from the front of the hood to the high rise is steeper on yours - almost like the L88. It looks like the rise starts ahead of the radiator support and reaches max shortly behind that. True?
The rise on Panic's hood looks more like stock. (BTW, nice scoop job panic! Did you do the glass work yourself?) The Ecklers hood fauxrs2 posted looks to have the same low angle rise. That's the low stock-like angle I want.
Old Feb 25, 2008 | 07:12 AM
panic's Avatar
panic
[QUOTE=MN80Vette;1564257731]
I wish i did...but, no, i didnt do that job myself, it's a work from a professional guy.
But i contributed for the design
Old Feb 25, 2008 | 07:13 AM
MN80Vette's Avatar
MN80Vette
Default Hope I'm not hi-jacking the thread, but...
Do either the fauxrs2' hood or panic's hood come up enough at the back edge to have cowl induction underneath? The stock hood on an '80 comes down to the firewall, windsheild wiper motor, and a few other obstructions. If either of these two hoods leaves a decent sized opening in the back, I'd keep the new Ram Air Box air cleaner I have now and hold off on another mod until I can afford a new hood.
Old Feb 25, 2008 | 07:20 AM
panic's Avatar
panic
On mine you've got plenty of room in the centre/rear area as you add the scoop rise to the high rise hood...
I have THIS under my hood and still there is room for more...
Old Feb 25, 2008 | 07:52 AM
MN80Vette's Avatar
MN80Vette
Panic, I've always liked your car.
Do you have a picture from inside looking forward that shows the back edge of the hood?
Does anybody else with a non-L88 high rise hood have a picture of that?
Old Feb 25, 2008 | 08:00 AM
panic's Avatar
panic
[QUOTE=MN80Vette;1564257983]..........Do you have a picture from inside looking forward that shows the back edge of the hood?
Nop, i dont have any, but i'll take a pic later on and post it here...give me a few hours pls
Old Feb 25, 2008 | 08:18 AM
Ganey's Avatar
Ganey
Eckler's has 2 of the hi-rise hoods- 68-72 & 73-.
Heights from Eckler's.
Hi-rise 68-72 is a little less than L-88 hood.
Hi-rise 73- is taller than L-88 hood.
Med rise 73-79 hood is only 7/8" lower than L-88 hood & all of these including Med rise 73-79 hood allow cowl induction.
Old Feb 25, 2008 | 08:41 AM
fauxrs2's Avatar
fauxrs2
Indeed the hood im descrining has a C4 style hump in the center, it supposedly provides about an 1 1/4" clearance improvement over a stock hood.
I'm interested in possibly adding this hood before a re-paint I am contemplating. I think it looks pretty sharp without being over the top in height.
but primarily im was hoping someone might have seen one and maybe even had a picture of one.
Old Feb 25, 2008 | 08:44 AM
fauxrs2's Avatar
fauxrs2
And if you do have one of these "lying around" and Bee-jay doesnt pounce I too would be interested
Old Feb 25, 2008 | 11:01 PM
MN80Vette's Avatar
MN80Vette
That's the time to switch hoods.
I wasn't thinking ahead to any mods under the hood when I media blasted my '80 and repainted it. I regret that because I will probably have to repaint the whole car when I finally get the discretionary cash in pocket to put on a high rise hood and the mods I want to fit under it.
To Ecklers hood
