Spark Plug Change Problem
Old Feb 24, 2008 | 04:27 PM
nutsy's Avatar
nutsy
Default Spark Plug Change Problem
just went to change plugs, figured should be easy but couldnt get wrench on. problem is shield is in way of getting wrench on plug. should i try and bend it ot loosen it from header bolt? its a 454. also what plugs should i get and what is gap? thanks. nutsy.
Old Feb 24, 2008 | 04:42 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Which plug is causing the problem? I have a BB and I had a PITA to change the #2 and #4 plugs due to the A/C compressor location, then one of the forum members told its much better to reach from the wheel well (after removing the tire of course), since then it only takes 10 min to change all 8 plugs.
Old Feb 24, 2008 | 04:47 PM
nutsy's Avatar
nutsy
the problem is the heat shield around all the plugs. its not lined up around plug.its off center and i cant get wrench on
Old Feb 24, 2008 | 05:14 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Oh! I missed that on your post, mine doesnt have heat shields so I dont have that problem. Maybe a thinner socket would do?
Old Feb 24, 2008 | 06:29 PM
Theiskell's Avatar
Theiskell
I am not sure what you need but it sounds like a “crows foot” might be just the ticket. I have a DD that I use one on the number 4 plug and would be a PIA if I didn’t have it.
Old Feb 24, 2008 | 06:55 PM
nutsy's Avatar
nutsy
also i went through the wheel well for the front 1 but the 2nd back i cant get and do i need to put these heat shields back on?
Old Feb 25, 2008 | 12:52 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I just use a set of heat resistance boots, they work very well.
Old Feb 25, 2008 | 02:15 PM
427-390's Avatar
427-390
I just did this myself this weekend. Believe me, with the heatshields in place, it's a real PITA to get the plugs out. One thing I did was to take the foam rubber insulation out of my sparkplug socket to give it a little more wiggle room to allow the socket to seat on the plug better. I did eventually get them all out. Good luck!
Old Feb 25, 2008 | 03:12 PM
77Vette4S&J's Avatar
77Vette4S&J
I haven't changed plugs in mine yet but I know one side has the shield and the other doesn't. The former owner was changing his plugs and forgot to put the shield back on one side and said it was such a PITA that he didn't want to put it back on. When I bought the car he handed to it me and said "if it matters to you you can put it on later but I ain't busting my knuckles to do it."
To Spark Plug Change Problem
