Differential Stub Axle
Old Feb 27, 2008 | 03:10 PM
79SharkMan's Avatar
79SharkMan
Default Differential Stub Axle
Ok....I've been told mine is/are in need of replacement by my mechanic..He told me that the part(s) are not the bad part, but it's the high cost of the labor involved since it seems that it's a rather labor-intensive type of work....I have absolutely no idea how to even think about doing this myself, but perhaps with coaching it may not be too bad....So, is it really that labor-intensive? Are the part(s) expensive? Can a novice at this type of work actually do it? Thanks for the input, as always. Peace
Old Feb 27, 2008 | 04:20 PM
Scott Marzahl's Avatar
Scott Marzahl
If you are mechanically inclined, have a GM shop manual for reference, have some basic tools, a good 90 degree snap ring pliers, a floor jack and jackstands along with more help than you'll need from the forum you can easily save yourself lots of money on labor to remove the stub axles and differential if required.
Sometimes there may be more worn than just the stub axles, but you won't know until you get the back differential cover off. Worst case your differential is full of metal fillings, the bearings are shot, the posi clutch pack is bad and you need a entire overhaul
Best case scenario is the improperly case hardened stub axles are just worn and you can get by with a replacement set.
Old Feb 27, 2008 | 05:07 PM
GTR1999's Avatar
GTR1999
Ask your mechanic what the endplay is in yours. 040,060, .125" more? If he doesn't know then do the job yourself or find another guy.
I have found a lot of the lower endplay figures are not always worn yokes but rather slop in the posi setup. Addressing one and not the other is only 1/2 the fix.
Look up my pictures, you'll see the yokes installed and what they should look like.
To replace them you have to remove the diff, there is a procedure for removing the rear cover on the car but that's not the way I'd do it. More chance of injury that way.
If indeed the yokes are worn a lot then they could be mushroomed on the ends and may require force to drive them out. Another reason to do this on the bench. Figure in new seals as well.
Old Feb 27, 2008 | 06:25 PM
79SharkMan's Avatar
79SharkMan
Thanks for the replies so far...The suggestions so far have been awesome
Is there an obvious way to tell if they're bad, or will I need to get into the guts of the differential before I'll know for sure?
Old Feb 27, 2008 | 06:42 PM
Scott Marzahl
As Gary asked, what is the supposed end play, or what prompted your mechanic to say they need to be changed.
Old Feb 27, 2008 | 09:13 PM
MakoShark77's Avatar
MakoShark77
St. Jude Donor '24-'26
Drop your stub/half axles and pull them back and forth, you'll know. You can do it without pulling the pumpkin, its not that bad really. There is a potential for other issues once you get it open. When your existing stub axles wore down, that metal went somewhere and could have caused other issues.
You didn't say...how many miles are on this rearend?
Old Feb 27, 2008 | 09:29 PM
79SharkMan's Avatar
79SharkMan
My car has 66k on it
Old Feb 27, 2008 | 09:35 PM
79SharkMan's Avatar
79SharkMan
I didn't ask him for specifics....He had it for about a week after I bought it and was replacing mostly front-end safety-related stuff...As far as why he said they needed to be changed, I couldn't really tell you without calling him to ask. (it has been awhile since he told me this) I'll try to do that in the next day or two to find out, and then I'll get back with you guys. I just remember him saying it was/could be labor intensive because of the amount of work it would probably take to replace the parts. Of course, there's no telling what could actually be found once that puppy is opened up.
To Differential Stub Axle
