After scouring past posts and pictures I am pondering putting 17 inch Torque Thrust II rims on my 73. I have several questions
1. What exact 17X8 rim specifications do I need, ie offset and back spacing? Better yet, what model number wheel are you all using?
2. If I put 255/50/17 tires on these rims, will I experience rubbing problems on a 1973? I have read a number of thread where guys are running 255/60/15s on stock rims and have rubbing problems. I am currently running 245/60/15s on 15X8 with no rubbing.
3. It also appears my front end has been lowered an inch. Could this cause a problem going to the 17 inch rims?
When the 255's rub, is it something you just hear and back off of, or do horrible things happen to the tire?
Glenn
Actually, you don't hear or feel it but you can see a shiney spot on the frame where it contacts. Not really an issue.
By the way akfox1, love that pic of your car. It been the wallpaper on my computor for quite some time. I'll be painting my Vette Lemans Blue when I get to that point.
