Washer pump filter for '75??
Old Mar 6, 2008 | 01:30 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Default Washer pump filter for '75??
I pulled the old useless washer pump and got a new one. Now I can't find the damn mounting nut with the integrated mesh filter!
Pump fits on the bottom of the reservoir and has this large plastic nut on the inside of the reservoir that has a cone shaped filter on it. Can't find the nut in the house (hey!), and can't seem to find it online either.
Anyone have any idea where I might find one or at least a plastic nut that size?
Old Mar 6, 2008 | 01:53 PM
Overlord's Avatar
Overlord
N'er mind. Found it on Dr Rebuild.
Don't much like that page at a time .pdf format for the catalog tho.
And, of course, might as well order other crap as long as I'm in there
Old Mar 6, 2008 | 02:04 PM
Durango_Boy's Avatar
Durango_Boy
I replaced my old washer pump with a new one, well, a new two, from a Jeep reservoir. I split them so each pump has it's own line to it's own wiper.
Old Mar 6, 2008 | 02:42 PM
Overlord's Avatar
Overlord
I recall your dual pump config. Did you run them to wipers or sprayers?
If suspect you can just blip your washer control to hose everything down.
'Tis a pita just to get the tank out of the fender.
I would consider the larger(?) dual setup reservoir but with everything else spawning it's own nuts, screws, parts as I take them apart/out, don't really want to take time to fab a tank mount.
Old Mar 6, 2008 | 02:45 PM
Durango_Boy
I just used the stock rubber lines from the wipers, and where the 'T' to go to the one pump I simply left them individual, one for each pump. It's been so long since I used the washer I can barely remember if it's drizzles all over the windshield or if they spray. I think it's the drench effect, which I don't mind at all.
To Washer pump filter for '75??
