Spray Booth - Houston area
Long read, have plenty of time to do it.
http://mckennasgarage.com/
http://picasaweb.google.com/BubbaTruck/CarPaint
The key thing is you need to have a place where you can spray where you can reduce or minimize dust and other particulate. This can be a spray booth, but it can also be your house garage. You can do this in a garage if you blow off the garage walls and ceiling and clean and wet the floor prior to spraying. I prefer to spray outside but it's critical to choose the right location and time. It has to be on a cloudy day and not under trees. Start early, don't do on a hot day. If the sun comes out, you're tanked.
Also, as for spraying in a booth, it takes a leval of experience to get good results. First of all, not all spray booths are well maintained. I've seen guys get big gobbs of crap in their paint from material that fell off the filters. If they run a lot of negative pressure and someone opens a door, you can get lots of dust/material in the paint job. Also, the air-flow characteristics and lighting can conspire to produce an undesireable finish. Poor lighting leads to orange peel and/or runs or poor metal flake lay-out. Guys that spray in the same booth all the time, learn how to work around the booth and also know how much paint they can "push" and how quickly the reducers will evaporate. Outside, you'll have the best lighting you'll ever have. Plus fumes are a non-issue. I don't have close neighbors, but that might be an issue for some.
I've sprayed in a couple different booths. I found it difficult to go from one booth to another. Ya aren't used to the lighting, the air flow isn't the same, etc. I'm used to my garage and I've gotten nice paint jobs. Bear in mind that the most dust will likely come from your clothes, hair, the floor or dust that's trapped in folds of the masking paper. These are easy to eliminate. Personally, I've grown to accept that I will get some dust and a few minor boogers in the paint, but now I know how to tackle them. With clearcoat paints, the boogers can for the most part be eliminated after the fact. Also, I've known a lot of good painters and they'll say that there is almost no such thing as a perfect paint job. I've seen these guys jobs out of the booth and there is almost always a small sag or two if you get really critical. Anyway, good luck, ...booth or no booth.
I actually was hoping to especially gain the infrared drying from the boothe. The newer paints are tougher and I was just thinking the infrared cure would make it even tougher (ie: better). Now that you challenged me, you make me realize that with or without cure, the new paint is more resilient than lacquers.
If I cannot land a boothe - you bet - the garage will be hosed with air, taped with plastic and an attempt at filtration/venting. The wet floor is a must.... HEY ! maybe I will devise a DOWNDRAFT platform in my garage
$600.00 for the weekend.
Drop me a line and we can work out the details.
Skip in Houston
