Air cleaner clearance
Old Mar 18, 2008 | 10:01 PM
lozzas69's Avatar
lozzas69
3rd Gear
Default Air cleaner clearance
I have a problem with the air cleaner on my 1969 Big Block hitting the underside of the hood. I am running an Edelbrock RPM AirGap Manifold and BG Speed Demon Carb , hood is an L88, filter is a small K&N sitting on top of the carb. I have seen some 69’s in magazines and on the net running similar carb/manifold set ups using a drop base air cleaner. I have tried various drop bases but all seem to hit the front of the cowl induction opening. Does anyone know how or the parts I can use to make this work. I really like the way it runs so was hoping to keep the setup. Thanks
