Maybe a dumb Question
Old Mar 21, 2008 | 05:02 PM
1stCorvette69's Avatar
1stCorvette69
Default Maybe a dumb Question
I am going to use sound deading, When I finaly finish my car. if I use the foil back stuff should I also buy the orig, Dash underlayment, Is it overkill? and would it cause problems with interior parts not fitting? Just checking before I buy.
Old Mar 21, 2008 | 10:11 PM
Durango_Boy's Avatar
Durango_Boy
The stock stuff is for heat, sound deadening is for sound. Lay down the sound stuff first, then heat stuff over that, and everything should still fit fine. Trim where you have clearance problems.
