LS-4 alternator mounting
Steve
This shot offers a glimmer of light. While this doesn't have the original alternator (anyone know what model alternator this is?), it does have a double groove pulley, and the belt is running in the outermost groove. This would most certainly solve my belt alignment problem, but the AIM manual and the service manual do not show the alternator with a double groove pulley. And I just don't recall these engines utilizing a double groove pulley.
Interestingly, I just looked in Zip Corvette's newest catalog and they list a separate pulley for the '72-'74 454 with power steering vs. non-power steering. Dr Rebuild also lists a separate pulley. It looks like I'm going to need to find a double groove pulley (or order one). Can anyone else confirm the use of a double groove pulley?
Steve
So tell me what is wrong with my installation. Here are some photos, and yes, they are lousy. It's tough to get a good shot with the hood in place. Ignore the aluminum bandaid holding the fan shroud together. And realize the AIR pump and the A/C compressor are still sitting on the bench. As you can see in the first photo, the alternator belt runs in what the AIM calls the "third track", and lines up perfectly with the outer groove on the power steering pump pulley and the outer groove on the new alternator pulley. If the A/C compressor and AIR pump were in place, that belt would run from the empty outer pulley on the water pump.
Two closer shots:
All belts are tracking straight, and are in the proper pulleys. All mounts have been replaced, and everything fits properly. The idler pulley is in place and provides additional tension on the "first track" cranshaft to water pump pulley belt. So what's up here? Why would I need a two groove pulley if a one groove is specified? Oh, and the AIM lists two different pulleys; one for A/C with P/S and one for A/C without P/S, but of course there isn't any way to tell whether the difference is the number of grooves. What would be the difference if not the number of pulleys? The diameter of my single groove and two groove pulleys are the same.
Sign me:
Steve the Baffled
In one of the pictures, the alternator mounting bracket looked a bit strange. I'll try to remember to take a look at my configuration to see if I can help clear up the confusion. Obviously your belts line up the way they are supposed to.
After viewing my configuration, it appears that your double-pulley may possibly be a service-replacement part designed for many configurations across multiple years and models. The alternator pulley on my '74 LS4 with power steering, AC, and AIR appears to be the same size as yours front-to-back, however where you have the inner pulley, I have a solid area - maybe an un-machined area intended to provide the necessary spacing in this particular configuration since the second/inner grove is not required.
So your alternator pulley fits just fine, and your belts (at least on that side) appear to be in the proper configuration. You just have a "spare" groove in the alternator pulley.
I'd post a pic now, but my camera is MIA. Maybe someone else has a pic of their alternator pulley?
Steve
