Stem valve over size ???
Old Mar 23, 2008 | 04:45 AM
avner's Avatar
avner
Default Stem valve over size ???
My heads have 1.600 Exhaust & 2.020 Intake Valves.
I have too mach freedom between the stem & the hole and my stem valves diameter are already + 0.003.
Where I can buy valves 2.02 + 1.6 with standard length (4.911) & over size stem diameter?.
The standard stem is 11/32 = 0.3415.
I need + 0.006 - +0.010 or 0.347 - 0.351 stem diameter.
Avner
Old Mar 23, 2008 | 05:31 AM
SteveG75's Avatar
SteveG75
Pull the heads and have bronze bushing valve guides installed. That is the proper way to fix the problem.
Old Mar 23, 2008 | 05:40 AM
avner's Avatar
avner
My engine is 327 the heads are out allready.
I have new set of std valves.
Do you know what guides/bushing I need & where to buy them?
Avner
Old Mar 23, 2008 | 09:12 AM
SteveG75's Avatar
SteveG75
A good machine shop will drill out the old guides, press in bronze ones and then ream them to the correct size. This is fairly standard and easy for a machine shop in the US but I see that you in Isreal. You need to find a machine shop that can work on a small block chevy. This is not a do-it-yourself kind of thing.
Oversize stems will just wear the guides out more and cause the problem to come back.
Old Mar 23, 2008 | 09:17 AM
'75's Avatar
'75
, plus the guides don't wear evenly, the holes are no longer round.
Old Mar 23, 2008 | 10:19 AM
avner's Avatar
avner
The heads are original without guides, someone just enlarge the hole and put valves with oversize stem dia' +.003.
Avner
To Stem valve over size ???
