Carb bolt torque specs
Old Mar 23, 2008 | 02:07 PM
LT102's Avatar
LT102
Default Carb bolt torque specs
Can't find it in my books, I've looked thru all of them. It's got to be in there, but I can't find it. What would be the torque specs for the carb holddown bolts? I have a 1976 L48 with a Rochester. Thanks
Old Mar 23, 2008 | 02:24 PM
Duke94's Avatar
Duke94
I agree, it's not easy to find. Never could find it in my 71' manual. The 79' manual says when a new insulator is used "Tighten bolts alternately to 144 in.lbs.". If bolts are retorqued w/o carb removal then retorque in a clockwise direction. If less than 60 in/lbs, retorque to 96 in.lbs; if greater than 60 in.lbs, do not retorque."
