camel hump heads
Old Mar 24, 2008 | 09:39 AM
Ralph Rifon's Avatar
Ralph Rifon
5th Gear
Default camel hump heads
new to corvette form have question about installing early model 350 camel hump heads on 81 engine block.aternator mounting is my problem has anybody done this and what mounting brakets to use.heads are drilled but not for late model alt installation. Thanks Ralph
Old Mar 24, 2008 | 09:50 AM
markdtn's Avatar
markdtn
You can use brackets like a C2 but IMHO dump those heads and get a set of Vortecs. They flow better and already have hardened seats, you will be money ahead in the long run.
Old Mar 24, 2008 | 02:18 PM
WillEE's Avatar
WillEE
If you already have these camel humps no need to dump them and spend more if they are in good shape. I had a set on my '68 Camaro and then switched to Edelb. RPM and didn't even notice a difference in seat of the pants feel from one to the other. They are good heads. I gave my set to a good buddy who used them on an engine for his 56 GMC P/U which he just started the other day and called me to listen. They need hardened exh. seats if not already done. If they need lots of work then agree w/vortecs but then you have to get new manifold - depsite what they say about being interchangeable they are not. Bolts line up but openings do not line up well at all and will restrict flow. The big drawback with the humps is the lack of accessory mounts. There are plenty of bracket options out there - most using the #1exhaust holes to attach a bracket.
Old Mar 24, 2008 | 03:02 PM
dmayhew's Avatar
dmayhew
PM sent
Old Mar 24, 2008 | 03:54 PM
bashcraft's Avatar
bashcraft
They don't need hardened seats, unless you're going to use them on maybe a dump truck.
Old Mar 25, 2008 | 03:22 PM
WillEE's Avatar
WillEE
I have know idea what you mean by that but the fact is that they do need hardened seats on exhaust sides unless you want to do head work more often then you should. Keep in mind these heads were pre- unleaded fuel days.
Old Mar 25, 2008 | 04:09 PM
markdtn's Avatar
markdtn
I agree, if you do more than putter around you need hardened seats on the exhaust. I have seen a set of Pontiac heads with the valves sucked in and all the rocker arms loose. Car was run hard occasionally, mostly just cruised. Camel hump or double hump heads were great back in the day, but they just don't flow like modern heads. I suppose if you had a set worked and ready they might be ok, but I would sell even those to a restorer and get something new. My .02
Old Mar 25, 2008 | 04:11 PM
75 Red Vert's Avatar
75 Red Vert
You can by lead treatment at any auto parts store to add to your gas.
Old Mar 27, 2008 | 06:58 AM
bashcraft's Avatar
bashcraft
If the rocker arms were loose, the valves didn't sink. That would've caused them to be too tight.
Unless the engine is always being heavily loaded, like in a dump truck, non-hardened seats will not be a problem. Just make sure that you don't use the stock rotating spring retainers.
Old Mar 27, 2008 | 08:52 AM
tomply32's Avatar
tomply32
Default hump heads
sell them and install a quality set of aluminum/iron heads you will be glad you did .old teck there and not worth modifying/rebuilding unless # match originality is wanted
To camel hump heads
