I need to pull off my rear passenger caliper (70 vert)to see why my emergency brake shoes are not spreading. The brake line runs over the through bolt (I'll have another question about that). If I remove the brake line (or should I chance bending it out of the way) is there a possibility of the flair going bad (leaking) ?
Question#2 - I had ordered new brake caliper bolts (Wilcox).When I received them, they are about 1 1/2" long (8 in total) I thought I would be receiving new through bolts. The box does say caliper bolts. Emailed Wilcox - no reply. What would these bolts be used for ?
