Help with engine casting number
Old Mar 28, 2008 | 05:09 PM
Vampyre's Avatar
Vampyre
Default Help with engine casting number
I am looking at a 1974 C3 Vette with non original engine
As best I can tell casting number:
C6J118314 1020TXD
any idea what 350 this is?
thanks
Old Mar 28, 2008 | 08:07 PM
Vampyre's Avatar
Vampyre
Thank you very much! Yes I was missing the "V"
Would this be a reason to stay away from this 1974 Vette?
The HP seems about right for a 1975 motor, but wow did they restrict that output, how hard is it to up that?
Any idea what the torque specs are on this motor?
thanks
Old Mar 28, 2008 | 08:47 PM
Vampyre's Avatar
Vampyre
Well it sounds good, and felt ok, but I only test drove the car lightly, I didn't get into it, and only drove down a short road ,since the car has no plates on it.
but at 3400lbs with 163HP, it isn't fast no matter what, I'm guessing.
Just wanted to know if this was a good base engine, to start with, the car is in ok shape,. frame is nice, body needs paint badly, has some real bad alligator looking patches.
Other issue I saw .. Steering wheel has LOTS OF PLAY... I was told the "Rag Joint" was worn, not sure if that is even a real expression.
if the link works here are some pics, also has 1982 rear bump on this vette
http://s268.photobucket.com/albums/j...tte/?start=all
Old Mar 28, 2008 | 09:13 PM
elevatordude's Avatar
elevatordude
on the 3970010 check if it is made in mexico ..many were and rag joint is a real part it is on the steering shaft
Old Mar 28, 2008 | 09:21 PM
Vampyre's Avatar
Vampyre
thanks for the info...
If it is made in Mexico, is that a bad thing?
were you able to see the photos at the link I posted?
could a worn rag joint cause excessive play in the steering wheel?
Old Mar 28, 2008 | 10:17 PM
Artsvette73's Avatar
Artsvette73
A 1976 block would not have been built in Mexico. They didn't start till the 80's. The block will be a good base to build on.The C20 and C30 had four bolt mains. As far as the rag joint being the problem, yeah it could be, but expect more that that.
Old Mar 29, 2008 | 10:11 AM
Mike Ward's Avatar
Mike Ward
thanks
That's what the engine produced when installed in the original vehicle. No telling what's been done to it since then.
After looking at the pictures and seeing that it's a NOM base engine car with auto trans, incorrect colours, bad body work, bubba'd interior, questionable steering etc. - I hope the asking price is really really low.
You'll be financially upside down on this car as soon as you start spending money if that's a factor to you.
Edit: never mind, I saw your other post asking for value. Run away from this car, it's junk
To Help with engine casting number
