worth 5K?
Old Mar 28, 2008 | 11:30 PM
Vampyre's Avatar
Vampyre
Default worth 5K?
Looking at this
1974 C3 Black (original color was white)
Non original motor
TXD = 1976 350ci Truck 165hp LS-9 TH350 4-Brl C-20 & C-30
both Side window Weather stripping is all bad, needs to be replaced
lots of slop in the steering wheel, can move it about 3 inches with no direction change.. told the rag joint was bad.
real Bad paint on the doors , but hood and trunk ok.
mirror tops
rear bumper is from an 1982, with spoiler
Frame looks good, from what I can see
I posted a bunch of photos here. I added photo descriptions to help.
http://s268.photobucket.com/albums/j...tte/?start=all
any input please.
thanks
Old Mar 28, 2008 | 11:56 PM
c3 in hawaii's Avatar
c3 in hawaii
IMHO that's a bit high, first off it needs a complete strip and paint which can run you into some big $$$,
obviously not the original engine, got some major fluids leaking from the engine and/or power steering, probably needs a complete front end rebuild which will also be costly. interior not bad off but does need help.. But my main concern is with this.
Compare the two, on the first pic seems like the body mount is separating from the body.
seems like there is a rust hole in the frame where the crossmember meets...
have you pulled the kick panels to see how those body mounts are?
If it were me I would probably pass on this one..
Old Mar 29, 2008 | 12:07 AM
Jon Hekking's Avatar
Jon Hekking
I don't see $5K worth of car here, I see a car that is going to take major $$$ to get presentable let alone dependable. I would add a few thousand to my buying price and find a better car to start with, they're out there. I think I would walk away..............
Old Mar 29, 2008 | 12:18 AM
pbcanney's Avatar
pbcanney
uh
no
I wouldnt
Old Mar 29, 2008 | 12:51 AM
FRSTR90's Avatar
FRSTR90
I think you can find much better deals...
Old Mar 29, 2008 | 06:53 AM
Vampyre's Avatar
Vampyre
Thaks Guys...
I really appreciate the input... I'll pass on this one too.
thanks!
Old Mar 29, 2008 | 08:13 AM
irvan's Avatar
irvan
Was told years ago it is much cheaper to buy one than to build one.
Old Mar 29, 2008 | 09:33 AM
79L48's Avatar
79L48
Seems a bit high to me. This is a lot of "project" and a little "car". You're looking at 3-4K to make the interior right...and that should be the last thing you do. I would run.
Old Mar 29, 2008 | 09:39 AM
justasbad's Avatar
justasbad
stay away
Old Mar 29, 2008 | 03:50 PM
Roughrider's Avatar
Roughrider
Can you say "P-A-R-T-S C-A-R"?
Old Mar 29, 2008 | 04:55 PM
Aggitated Monkey's Avatar
Aggitated Monkey
It will take alot to bring it around. Not sure about that hole in the frame where the cross member meats the rail. The car has too many layers of paint and will need to be completly stripped, includint the jambs. It's workable; just not a 5K car. Maybe $1500-$2500.
Old Mar 29, 2008 | 05:28 PM
dodge_ss/t's Avatar
dodge_ss/t
i wouldent go that far but its sure not worth 5k lets say round 2500tops.
Old Mar 29, 2008 | 05:34 PM
Vampyre's Avatar
Vampyre
thanks again,
I am passing on this car, I'll just keep looking, but figured I would bump it off you guys first.
Old Mar 30, 2008 | 11:18 AM
spike1360's Avatar
spike1360
There are a lot of cars that people almost finish but run out of money or need to sell for some other reason. Patience is key.
Old Mar 30, 2008 | 11:59 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
To worth 5K?
