C2 needing C3 help
Old Mar 29, 2008 | 10:04 AM
CWerner's Avatar
CWerner
Default C2 needing C3 help
My 64 Resto-Mod has an 82 aluminum rear end. It has started leaking very slowly, but I don't see any source location.
I'm considering putting some rear differential stop leak in it.
Is this a common problem with these rear ends or is this abnormal? The resto was done 12 years ago and it has 20k miles on it since.
Comments or suggestions would be welcome.
Old Mar 29, 2008 | 10:43 AM
dannyman's Avatar
dannyman
PM Gary , he is the resident rear end guru. He can help you!
GTR1999
Good luck
Dan
Old Mar 29, 2008 | 06:57 PM
72LS1Vette's Avatar
72LS1Vette
Just a wild-a$$ guess but is the vent filter at the top of the diff missing?
Rick B.
Old Mar 30, 2008 | 01:15 AM
Fuelie74's Avatar
Fuelie74
I would recommend against using stop leak products in anything. It will cause you nothing but problems. If you can't find the leak put some die in it, drive it for awhile and check it with a UV light.
To C2 needing C3 help
