Seat Belt Problem
Old Mar 29, 2008 | 05:00 PM
Fuelie74's Avatar
Fuelie74
Default Seat Belt Problem
I am installing 94 F body seat belt in my 74. I have searched all of the seat belt threads and am not sure what I am doing wrong. The right side retractor points to the center counsel. It looks like retractor is to wide when bolted in. Any thoughts on what I might be missing?
Old Mar 29, 2008 | 07:22 PM
Durango_Boy's Avatar
Durango_Boy
I think you are using too old of F-body belts, and also, you are supposed to use the rear belts. Do you have the rears or the fronts?
Old Mar 29, 2008 | 10:07 PM
Fuelie74's Avatar
Fuelie74
I have the rears. They came out of a 4th gen and to be honest I think it was about a 94 but maybe a 95. I didn't really look at the year but know it was around there because I was drooling over the LT1 and 6 speed.
Old Mar 29, 2008 | 10:21 PM
Fuelie74's Avatar
Fuelie74
Hear are some photos.
Old Mar 29, 2008 | 11:10 PM
Durango_Boy
I seem to remember that when I looked into F-body seat belts, I was told to look for the last Gen Camaro belts, as in the '01 area version.
Old Mar 29, 2008 | 11:28 PM
jim2527's Avatar
jim2527
There's a stud on the wheel well just forward of the bolt hole that may be interfering with positioning. I flattened the positioning stub on my retractors.
Whats the difference between them? Early vs. late?
Old Mar 30, 2008 | 08:54 AM
redwingvette's Avatar
redwingvette
I had to elongate/slot the hole in the retractor mounting plate so that I could get them to line up straight with the back of the trim panel, especially the passenger side.
Old Mar 30, 2008 | 12:49 PM
Fuelie74's Avatar
Fuelie74
Wont that weaken the mount? I am doing the swap for the safety of my son and wife (had lap belts only before).
Old Mar 30, 2008 | 01:47 PM
Duke94's Avatar
Duke94
This thread has lots of photos and info on doing the Camaro belt install. I made this change on my 71' and didn't have to change anything except widen the slot in the plastic trim panel where the belt comes through.
http://forums.corvetteforum.com/show...maro+seatbelts
Old Mar 30, 2008 | 01:53 PM
Fuelie74's Avatar
Fuelie74
Thanks for the pictures. I was concerned about the angle of the retractors, but now I know that it will look and fit fine once I buy the covers.
Old Mar 30, 2008 | 07:32 PM
Fuelie74's Avatar
Fuelie74
Ok so its all done now and I sat down and buckled in. The seatbelt seems very short. some of the threads I have read say it will give you more room than factory. I have mine attached on the B post instead of going threw the seat like many. My lower anchor point is the factory retractor bolt. Any thoughts on that?
Old Mar 31, 2008 | 07:01 PM
Duke94's Avatar
Duke94
Did you buy the F-Body REARS or FRONTS (you need the rears)? Originally I had mine going around the seat also and even with the seat all the way back, it had plenty of length.
Old Mar 31, 2008 | 07:42 PM
Fuelie74's Avatar
Fuelie74
I bought rears for sure (I pulled them myself). Don't get me wrong I have enough room myself. I am more worried about having a bigger friend get in the car.
Old Mar 31, 2008 | 08:26 PM
jim2527's Avatar
jim2527
You should worry if the girl getting in is bigger than you...
Old Mar 31, 2008 | 08:42 PM
Fuelie74's Avatar
Fuelie74
How did I know that was coming. I don't have to worry about that. My wife is not over weight and she won't let me have a girlfriend. So no chance of having an over weight woman in the car.
To Seat Belt Problem
