pinging after start up from storage?
Mar 30, 2008 | 09:22 AM
Toronto Events Coordinator
Tank was full, had stabilizer in it, warmed it up for a good 15 minutes. Drove slow the first few miles, then on hard acceleration, pinged like crazy.
It's Lar's tuned, although that was 2 years ago, but nothing touched since.
Any ideas?
Mar 30, 2008 | 09:38 AM
Get that old gas out, get new gas in, I would even add some Sea Foam to the gas.
What were your temperatures when you were driving hard?
Mar 30, 2008 | 09:50 AM
Quote:
Originally Posted by
Durango_boy
Temp was normal, and as mentioned, the tank was filled with fresh gas in October and treated with StaBil. Never had this issue before
Dya think I could just add some Sea Foam into the old gas?
Mar 30, 2008 | 09:53 AM
RAGGDOLL
I guess I was thinking the gas was 2 years old based on the Lars mention...you just meant it's been stored since Oct. with a full tank. Okay, that's a lot better than 2 years. In that case Sea Foam won't do much.
I would look into timing, as you may be advanced a bit, and your fuel mixture might be subject too, considering it was treated with Stabil.
Mar 30, 2008 | 10:00 AM
a lazy lifter it will fix itself
Mar 30, 2008 | 02:35 PM
check your mec. advan?
mine was froze solid when i got it(vac was out too)
hahah straight timeing
Mar 30, 2008 | 04:53 PM
V77Vette
As mentioned, tune was done by Lars 2 years ago, so highly doubt anything there....
Will run out the old gas and see how it is on fresh 89 octane.
Mar 30, 2008 | 05:57 PM
its a machine things happen event if it was tuned, 327 in my boat pro rebuilt ran for a summer put it in heated storage got it out changed oil ran good till first time at the lake....spun bearing.
Mar 30, 2008 | 07:47 PM
Clogged jets? You might be running lean?
Mine sprang a fuel leak efter hibernation. The fuel hose seems to have "shrunk" and didn't make a tight seal against the pipes.
