The AC works but does not really cool very well in hot humid weather. when the weather is nice, I take off the t-tops and roll the windows down. That's when I like to drive the vette anyway. The AC leaks freon slowly, so I would need to replace the hosing and maybe even the condenser and who knows what else to make it right.
I hear it weighs about 180 pounds (?), I need to restore the radiator and thought when I did that, I would just remove the entire AC system and reap the extra horse power (?) and lighter weight.
My personal opinion, it isn't that much in the way that I would worry about it. I intend to get mine recharged to blow cold sometime. It works on mine, the compressor kicks on, it just doesn't blow cold.
any experiences on this??
Don't butcher your car.
180 lbs? No way.
Take the compressor and condenser off if you want to but keep everything you take off.
The AC unit is not 180 lbs, had mine off during the frame off (35-40 lbs. tops). I re-installed mine, just removed the belt, and mine works, I just never use it. I'd rather have the tops off and windows down.
From someone on the opposite end of your problem, I'd say don't do it. I'm looking to get AC on my car, and it's a lot harder to add it then take it off. If you ever change your mind, or decide to sell it to someone that wants AC you'll regret taking it off. Plus, once the AC, or any system like that comes off, it'll likely never be completely "correct" again, I.E. factory looking or functioning.
i rebuilt my ac system last summer on my 79 , cost about $550, rebuilt compressor, rebuilt hoses, (rebuilding the hoses is cheaper than new ones) , orings and ac flush,freon, plus renting a vacuum pump and gauges. new evaparator sensing switch. plus had to replace vacuum switch inside console. added a manual hot water shutoff valve for the heater lines. and extra relfectix insulation under the carpet.
converted to 134A. it cools quite well, 47° air out of the vents , even for texas.
Do leave it on. When I got my 1970 the previous owner took almost all AC stuff off. Wish I had it and it would be expensive to replace. Spring and Fall is when I drive the most. July & August super hot feet.
Just bypass it (leave everything intact, but no belt running to the compressor). That way you won't keep turning it if you're not going to use it, but don't have to remove the whole system. If you change your mind later it will be a lot less work. The weight isn't enough to be significant and the pulley won't be spinning with the belt removed so that eliminates all possible HP loss.
The collective knowledge and experience from the forum members is great. I will keep my AC and see if I can either fix it or just remove the belt. great advise, thanks to all.
