Took out interior today, need help with identification??
Old Mar 30, 2008 | 09:50 PM
TyCor's Avatar
TyCor
Default Took out interior today, need help with identification??
I am gutting the interior of my '77, good lord, it was ratty. I have only had the car for about 2 weeks, and have never attempted such a project. I need some help identifying two things??
I found them behind the radio, one of them has an in-line fuse attached to it...the black thing looks like a motor of some kind...HELP!!
Old Mar 30, 2008 | 10:02 PM
hnkajnk's Avatar
hnkajnk
The first one I believe is the courtesy light delay. I am not sure about the other.
Old Mar 30, 2008 | 10:09 PM
'75's Avatar
'75
the second one looks like a relay with the cover missing.
Old Mar 30, 2008 | 10:32 PM
Glassbowtie77's Avatar
Glassbowtie77
The courtesy light delay is cylindrical and looks like a flasher. It is taped to the main harness in between the speedometer and tachometer right under the dashpad.
Old Mar 31, 2008 | 07:57 PM
TyCor's Avatar
TyCor
anyone else have any ideas as to what this is...both of these are attached to the cars underdash wires as well as the radio harness.
Old Mar 31, 2008 | 08:17 PM
Duke94's Avatar
Duke94
Nothing like that on my 71' or 78'. The ones with the white/clear connectors don't look like GM connectors. Can you trace the wires backward to see what's on the other end?
Old Mar 31, 2008 | 08:21 PM
'75's Avatar
'75
Can you get a picture showing all the wire colors?
Old Mar 31, 2008 | 09:58 PM
TyCor's Avatar
TyCor
Here are some additional pics. Now that I take a closer look at it, could it be for the power antenna...the white, green, brown wires look similar to the antenna wires.
Old Mar 31, 2008 | 10:16 PM
Glassbowtie77
Just a thought here, does your car have a rear window defroster?
Old Apr 1, 2008 | 06:04 AM
TyCor's Avatar
TyCor
Yes, it has a rear windown defroster.
Old Apr 1, 2008 | 06:11 AM
corvetteload's Avatar
corvetteload
Purchase a wiring diagram, they are priceless when you are in the state of disassembly you are.........B
To Took out interior today, need help with identification??
