Removing brake lines
Old Mar 30, 2008 | 09:52 PM
selecw's Avatar
selecw
Default Removing brake lines
I'm in the process of fitting new stainless lines my front calipers, and I can't get the old lines off.
I got them off the caliper end fine, it's the other end that's the problem.
Any tips? Pliars? Special tool?
Old Mar 30, 2008 | 10:56 PM
69 Convertible's Avatar
69 Convertible
If your using a regular wrench, try a flare wrench. It will give you a better hold on the fitting. I think that what there called. Ask the guy i nthe tool store. Tony
Old Mar 30, 2008 | 11:04 PM
69 Convertible
Here's a pic of the tool.
Old Mar 30, 2008 | 11:57 PM
selecw's Avatar
selecw
Got it, thanks. Picking some up from Sears tomorrow.
Old Mar 31, 2008 | 01:15 AM
1981Z06Vette's Avatar
1981Z06Vette
Even with a good flare wrench, sometimes the fitting just won't come loose. If thats the case, and you are replacing the lines anyway, a set of vise grips will often work great.
Old Mar 31, 2008 | 05:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Another trick is to cut the line off flush with the fitting, then use a 6-point socket of the correct size to back the fitting out.
Old Mar 31, 2008 | 02:20 PM
selecw's Avatar
selecw
How easy is it to fit the "hard" lines if you make that cut?
Old Mar 31, 2008 | 09:47 PM
skipinhouston's Avatar
skipinhouston
Danger Will Robinson, danger.
Get the proper tubing wrench and give it a few taps with a brass hammer to see if you can free it up.
DON'T GET IN A HURRY AND....................................
Before you cut ANYTHING, be sure to look at which line you're trying to get off.
Most of them are pretty easy to replace, but if its the main line to the rear brakes, I'm pretty sure you have to remove the body to put a new one in.
Call one of your local Corvette club members and have them come by and give you a hand.
This is a wonderful resource and you meet some really nice folks this way.
If you're doing a body off, look at www.inlinetube.com for pre-bent replacement lines.
Good people, good products.
And good luck to you.
Skip in Houston
Old Mar 31, 2008 | 09:59 PM
selecw's Avatar
selecw
Do you have a source for the tubing wrench?
Old Mar 31, 2008 | 10:24 PM
stinger12's Avatar
stinger12
It's craftsman brand. Try sears
Old Apr 1, 2008 | 02:45 AM
1981Z06Vette
The Craftsman ones are excellent. I would be wary of any of the cheaper parts store brands; I have found that most of them flex too much, and are worse than using a regular wrench.
Old Apr 1, 2008 | 03:30 AM
al329's Avatar
al329
Made the mistake of buying the HF set....well get what you pay for....they flexed and rounded of the nuts!
Old Apr 1, 2008 | 09:09 AM
bop's Avatar
bop
Default brake lines
I replaced my front lines on my 71 ok. I was told the rear lines could be replaced without removing the body from the frame by a member that said he had done it. Havent replaced my rear lines yet the front ones turned out to a 3 hour job.
Old Apr 1, 2008 | 02:07 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
I replaced the 2 front lines on my '79, bought them from Corvette Central, reasonable price...also bought the wrenches at Advance Auto, appear to be a good quality...
Old Apr 1, 2008 | 06:34 PM
Bowerss2's Avatar
Bowerss2
I have heard them called "flare nut wrenches" but usually they are called "line wrenches". Craftsman are by far the best, or snap on. Pick up a good set at sears, they are handy any time you cant get a 6 point socket in, and do not want to round over a nut or bolt.
Old Apr 1, 2008 | 09:20 PM
72LS1Vette's Avatar
72LS1Vette
In addition to having the line wrenches, spray plenty of PB Blaster on the fittings and let them soak for a few days. Clamp a Vise Grip on the line wrench if you have room to keep it tight on the fitting and work the fittings loose slowly, turning them back and forth until they free up. If you are putting new lines in you don't have to worry about twisting the old ones but you don't want to damage the calipers or the distribution block.
Rick B.
To Removing brake lines
