my car wont crank
Old Apr 9, 2008 | 11:57 AM
a kungfu mastah's Avatar
a kungfu mastah
Default my car wont crank
Ive got a 78 L48. I turn my key gen light comes on all nice nice, hear the fan come on nice nice as well, low gas light comes on too, but thats because I F*cked up my rewiring of my gauges and am to lazy to rip it back out and fix it. I turn my key and my battery gauge goes down, but nothing happens. Dont hear the solonode click, just silence. Tried my wipers, those worked, my horn hasnt worked in a long time so I couldnt try that. headlights came on fine. Last time I ran it probably 2 weeks ago it started up just fine, or at least didnt have a problem cranking anyway.
help?
-ashton
Old Apr 9, 2008 | 12:20 PM
Durango_Boy's Avatar
Durango_Boy
Do you have a digital multi meter? You need to check your voltage at the battery and at the starter. I would assume you have a ground problem, and you're getting enough power for lights and stuff but the starter is not getting juice.
If you are in fact getting power at the starter, then the solonoid or the starter itself might be bad.
Old Apr 9, 2008 | 12:24 PM
a kungfu mastah
go check that now, the lead i test on the starter is the black wire correct?
I got approx 11.9 on the battery. I did notice when I turn the key the fan motor dies down though.
Old Apr 9, 2008 | 12:34 PM
guappy's Avatar
guappy
When you hold the key to start you should have battery voltage on the purple wire,but before you even try to start the car there should be battery voltage at the heavy lead which is the black wire.
Old Apr 9, 2008 | 12:37 PM
a kungfu mastah
alright ill hop out and try that in a few momentos, i need some food.
with the key turned I got 11.something i couldnt read from whats probably the purple wire, dirt/grease have made the similar colors. and by key turned I dont mean turned all the way to attempt to start.
Do i need to rebuild my solonoid?
Old Apr 9, 2008 | 03:12 PM
mdj21's Avatar
mdj21
your battery terminals aren't coroded are they?
my truck would do that to me some times. everything comes on but when you try to start..... nothing.
clean the battery terminals. the truck fires right up.
Old Apr 9, 2008 | 03:17 PM
a kungfu mastah
what do you suggest cleaning them with?
Old Apr 9, 2008 | 03:18 PM
eastltd's Avatar
eastltd
Have you tried to jump start the car?
Old Apr 9, 2008 | 03:40 PM
mdj21's Avatar
mdj21
baking soda with a little water applied with an old tooth brush works pretty well.
for post type batteries they make a special wire brush to clean the terminals. i've not seen one for these side terminal bateries.
Old Apr 9, 2008 | 03:49 PM
a kungfu mastah
the spot my car is in makes it hard to get cables to it, i can see if someone has 2nd set of cables, have to daisy chain them but I can probably try that tonight. ill also clean the posts before i try to jump it. I'll let you know hwo ti goes.
Old Apr 9, 2008 | 04:00 PM
Wuttin's Avatar
Wuttin
If you can't get it jump started get the battery charged. I'm guessing you don't have enough oomph with less than the full 12.6V charge. Do you have a tender?
Old Apr 9, 2008 | 04:05 PM
a kungfu mastah
no, ive got a sh*tty battery charger from god only knows.
do any retail stores carry the tender?
Old Apr 9, 2008 | 04:35 PM
Durango_Boy
Follow this link to find a local retailer of Tender brand battery tenders. Fantastic product.
http://batterytender.com/dealers.php...02e0a79427ed27
Old Apr 9, 2008 | 08:34 PM
Jon Hekking's Avatar
Jon Hekking
Are you sure it's your battery and not the security system doing it's job? Same thing happened to me when I first bought mine. Any time you use the key or power door lock to lock the car upon exit, you must open the door with the key. I locked mine with the power door lock but reached in as I had the T-tops off to unlock it and it did the same thing as yours because the security system will lock out the starter. The way to reset it is to lock and unlock your car with the key. Might be worth a try.
Old Apr 9, 2008 | 09:21 PM
a kungfu mastah
dont have power locks =(
Old Apr 9, 2008 | 09:47 PM
'75's Avatar
'75
I don't want to state anything too obvious, but have you tried wiggling the shifter while you try to start it?
Old Apr 9, 2008 | 10:26 PM
V77Vette's Avatar
V77Vette
I have had neutral safety switches give me trouble before is it a standard or auto?
To my car wont crank
Old Apr 9, 2008 | 10:37 PM
Jon Hekking
Don't need to have power locks, if you key lock your door and don't use the key to unlock it I'm pretty sure it will disable your starter, I could be wrong, if so someone will correct me I'm sure..........
I know it sounds too easy, but when this happened to me I called a corvette specialty shop and he told me to lock and unlock my doors a couple of times and it would reset the security system, it worked like a champ.
Old Apr 10, 2008 | 01:36 PM
a kungfu mastah
ill give unlocking/locking my doors a shot, i havent messed with it since i last started it but it cant hurt. and it is an automatic. Ill try messing with the shifter, right now im charging my battery via jumper, we'll see how that goes. AGH ITS SO NICE OUTSIDE
i let the jump go for about 10-15min, tried multimeter and it was at 13.something, still no dice. without the jump on it was at 12.5, it seems like its not getting the juice to start it. could my solonoid/starter be jammed?
i think i did have a solonoid die the day i got the car, could be a trend?
and i played with the locks, still no dice.
this is getting depressing =(
Old Apr 10, 2008 | 02:56 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Do you have anyone that can turn the key over while you tap on the starter with A hammer I know this sounds crude but it works and it will tell you about your starter if you tap on it and it startes the car, always carry a hammer ,no really get A new starter.The main wire going to the starter could be in need of some TLC the double jumper(cables) thing might work but Ive seen where A single set would not start a car .My die- hard did it again this year put it up in October let it site till April Started right up. I pulled the battery added some water cleaned up the cables added sound proofing to the batt area and tonight I put it all back together.
